주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 7640 Paper Roller Replacement
필요한 것
    1. HP Envy 7640 Paper Roller Replacement, Paper Roller: 1 단계, 이미지 3개 중 1개 HP Envy 7640 Paper Roller Replacement, Paper Roller: 1 단계, 이미지 3개 중 2개 HP Envy 7640 Paper Roller Replacement, Paper Roller: 1 단계, 이미지 3개 중 3개
      • Open the printer by pushing upwards on the plastic tabs located on the sides of the printer.
      • Remove the opening assist from its purchase by pushing it toward the front of the printer with a nylon spudger.
      • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
      댓글 쓰기
    2. HP Envy 7640 Paper Roller Replacement: 2 단계, 이미지 2개 중 1개 HP Envy 7640 Paper Roller Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the last ten 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise.
      • Remove the last two 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise; the screen plate can now be separated from the printer by pushing out and to the right.
      • Take out the inner plastic frame (this piece is removeable after having removed the ten 12 mm screws outlined in the first bullet) by grasping the frame with both hands and carefully pulling the frame away from the printer body.
      댓글 쓰기
    3. HP Envy 7640 Paper Roller Replacement: 3 단계, 이미지 2개 중 1개 HP Envy 7640 Paper Roller Replacement: 3 단계, 이미지 2개 중 2개
      • Grasp the gray lever of the black plastic cover of the rollers and gently pull the lever up and to the right.
      댓글 쓰기
    4. HP Envy 7640 Paper Roller Replacement: 4 단계, 이미지 3개 중 1개 HP Envy 7640 Paper Roller Replacement: 4 단계, 이미지 3개 중 2개 HP Envy 7640 Paper Roller Replacement: 4 단계, 이미지 3개 중 3개
      • Press the lever outwards and away from the paper rollers with one hand.
      • Pull the paper rollers up and out of your HP printer with one hand while the other continues to depress the lever away from the paper rollers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nicholas Sheffler
회원 가입일: 01/24/18
408 평판
안내서 3개를 작성함
Cal Poly, Team S1-G2, Livingston Winter 2018 Cal Poly, Team S1-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G2
3 회원들
안내서 10개를 작성함
2가이드 댓글
is there a video
Joshua Williams - 답글 공유
Thank you, steps provided easy to follow.
Robyn McDaries - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 61
전체 시간: 8,728
