주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 7640 Screen Replacement
필요한 것
    1. HP Envy 7640 Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 HP Envy 7640 Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 HP Envy 7640 Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
      • Open the printer by pushing upwards against the plastic tabs on the printer body's sides.
      • Remove the opening assist by pushing it toward the front of the printer with a nylon spudger.
      • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
      댓글 쓰기
    2. HP Envy 7640 Screen Replacement: 2 단계, 이미지 3개 중 1개 HP Envy 7640 Screen Replacement: 2 단계, 이미지 3개 중 2개 HP Envy 7640 Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Place the T9 Torx screwdriver in the screw slot and turn counterclockwise to remove the two 12 mm screws that hold the screen manifold to the printer.
      • Push with minimal force to the right to dislodge the manifold from the printer body.
      • Lift the panel up and turn it over to reveal the green micro-controller board underneath.
      댓글 쓰기
    3. HP Envy 7640 Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Envy 7640 Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Undo the two connectors by gently pulling them away from the board.
      • Remove the last connector by flipping the tab up and pulling away from the board while also pulling left.
      • Remove the five 6.5 mm screws from the board using the T6 Torx screwdriver.
      댓글 쓰기
    4. HP Envy 7640 Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Insert the plastic opening tool into the space between the green board and the printer manifold and push downwards to dislodge the green board.
      댓글 쓰기
    5. HP Envy 7640 Screen Replacement: 5 단계, 이미지 3개 중 1개 HP Envy 7640 Screen Replacement: 5 단계, 이미지 3개 중 2개 HP Envy 7640 Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Peel back the tape that holds the screen in place.
      • Insert the plastic opening tool between the white screen backing and the screen to pry the screen backing from the adhesive that holds it in place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nicholas Sheffler
회원 가입일: 01/24/18
408 평판
안내서 3개를 작성함
Cal Poly, Team S1-G2, Livingston Winter 2018 Cal Poly, Team S1-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G2
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 35
전체 시간: 1,594
