주요 콘텐츠로 건너뛰기
HP Envy x360 15-bp143cl Fan Replacement
필요한 것
  1. HP Envy x360 15-bp143cl Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Fan Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Fan Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Fan Replacement: 4 단계, 이미지 1/1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Fan Replacement: 5 단계, 이미지 1/1
    • Detach the tape securing the heatsink to the laptop.
  6. HP Envy x360 15-bp143cl Fan Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to loosen the four screws securing heatsink.
    • The screws do not detach from the heatsink.
  7. HP Envy x360 15-bp143cl Fan Replacement: 7 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 4mm screws from the fan.
  8. HP Envy x360 15-bp143cl Fan Replacement: 8 단계, 이미지 1/1
    • Detach the cable connecting the fan and laptop by pulling from the white connector.
  9. HP Envy x360 15-bp143cl Fan Replacement: 9 단계, 이미지 1/1
    • Remove the fan from the laptop.
    • During reinstallation, be sure to remove old thermal paste on both the heatsink and CPU contact points. Then, reapply thermal paste using our How to Apply Thermal Paste guide.
결론
Spencer Berkins
회원 가입일: 10/10/19
574 평판
안내서 4개 작성하였습니다
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 회원
CPSU-REGAN-F19S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 604
