주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP G60T-600 CTO Power Button Frame Replacement
필요한 것
    1. HP G60T-600 CTO Power Button Frame Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Failure to remove the battery before performing any replacement guide may result in electric shock.
      • Close your device, then turn it over.
      댓글 쓰기
    2. HP G60T-600 CTO Power Button Frame Replacement: 2 단계, 이미지 2개 중 1개 HP G60T-600 CTO Power Button Frame Replacement: 2 단계, 이미지 2개 중 2개
      • Place your index finger on the ridged tab.
      댓글 쓰기
    3. HP G60T-600 CTO Power Button Frame Replacement: 3 단계, 이미지 1개 중 1개
      • Apply moderate pressure to the tab and slide it to the right.
      • While the tab is on the right, you should be able to gently slide your battery out of your device.
      댓글 쓰기
    1. HP G60T-600 CTO Power Button Frame Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 HP G60T-600 CTO Power Button Frame Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
      • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
      댓글 쓰기
    2. HP G60T-600 CTO Power Button Frame Replacement: 5 단계, 이미지 1개 중 1개
      • Turn your laptop over and open it up.
      • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
      댓글 쓰기
    3. HP G60T-600 CTO Power Button Frame Replacement: 6 단계, 이미지 1개 중 1개
      • Pull up on the top of your keyboard with medium force. It should start to pop out.
      • A plastic opening tool may facilitate this task.
      • Run your hands underneath the edges of the keyboard until it is free from the device.
      • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
      댓글 쓰기
    4. HP G60T-600 CTO Power Button Frame Replacement: 7 단계, 이미지 2개 중 1개 HP G60T-600 CTO Power Button Frame Replacement: 7 단계, 이미지 2개 중 2개
      • Place your thumbs on the two small, white tabs.
      • Push these tabs forward to release the connection and free the keyboard from the device.
      댓글 쓰기
    1. HP G60T-600 CTO Power Button Frame Replacement, Power Button Frame: 8 단계, 이미지 1개 중 1개
      • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
      댓글 쓰기
    2. HP G60T-600 CTO Power Button Frame Replacement: 9 단계, 이미지 2개 중 1개 HP G60T-600 CTO Power Button Frame Replacement: 9 단계, 이미지 2개 중 2개
      • Gently pull the white tab upwards.
      • With similar force, pull the connection out.
      • You are now free to pull the power button frame off of your device.
      댓글 쓰기
    3. HP G60T-600 CTO Power Button Frame Replacement: 10 단계, 이미지 1개 중 1개
      • Unscrew the 5mm screw holding the CD player in place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Dominic DeSantis
회원 가입일: 10/19/16
772 평판
안내서 6개를 작성함
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G5
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 402
