주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP G62-223CL Optical Drive Replacement
필요한 것
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: 1 단계, 이미지 2개 중 1개 HP G62-223CL Optical Drive Replacement, Battery Removal: 1 단계, 이미지 2개 중 2개
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
    댓글 쓰기
  2. HP G62-223CL Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully remove the battery from its compartment.
    댓글 쓰기
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1개 중 1개
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    댓글 쓰기
  4. HP G62-223CL Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
    댓글 쓰기
  5. HP G62-223CL Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 HP G62-223CL Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Garret Layton
회원 가입일: 01/13/15
687 평판
안내서 5개를 작성함
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 36
전체 시간: 1,528
