주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP G62-234DX Keyboard Replacement
필요한 것
    1. HP G62-234DX Keyboard Replacement, Wi-Fi Card: 1 단계, 이미지 3개 중 1개 HP G62-234DX Keyboard Replacement, Wi-Fi Card: 1 단계, 이미지 3개 중 2개 HP G62-234DX Keyboard Replacement, Wi-Fi Card: 1 단계, 이미지 3개 중 3개
      • Make sure the computer is turned off and disconnected from a charger.
      • Place your laptop on a clean, flat surface with the bottom facing up.
      • Slide the battery lock to the left.
      • Slide the battery out from the laptop while holding the lock to the left.
      • Remove the battery.
      댓글 쓰기
    2. HP G62-234DX Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP G62-234DX Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP G62-234DX Keyboard Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
      • The screws that are attached to the panel do not need to be removed completely.
      • Remove the back panel to access the Wi-Fi card.
      댓글 쓰기
    3. HP G62-234DX Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP G62-234DX Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP G62-234DX Keyboard Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
      댓글 쓰기
    4. HP G62-234DX Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP G62-234DX Keyboard Replacement: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
      • When the screw is removed the card will pop up at a 45-degree angle.
      댓글 쓰기
    5. HP G62-234DX Keyboard Replacement: 5 단계, 이미지 3개 중 1개 HP G62-234DX Keyboard Replacement: 5 단계, 이미지 3개 중 2개 HP G62-234DX Keyboard Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the Wi-Fi card by sliding it out from the socket.
      댓글 쓰기
    1. HP G62-234DX Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 HP G62-234DX Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 HP G62-234DX Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
      • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM chip.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Slide the RAM card out of the slot to remove it.
      댓글 쓰기
    2. HP G62-234DX Keyboard Replacement: 7 단계, 이미지 2개 중 1개 HP G62-234DX Keyboard Replacement: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove three 6.5 mm screws.
      • Use a Phillips #0 screwdriver to remove three 5.0 mm screws.
      댓글 쓰기
    3. HP G62-234DX Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP G62-234DX Keyboard Replacement: 8 단계, 이미지 2개 중 2개
      • Rotate the laptop back to its standard orientation and flip open the screen.
      • Use the iFixit opening tool to separate the keyboard from the tabs. Start from one point on the edge and work your way around until all of the tabs are released.
      댓글 쓰기
    4. HP G62-234DX Keyboard Replacement: 9 단계, 이미지 3개 중 1개 HP G62-234DX Keyboard Replacement: 9 단계, 이미지 3개 중 2개 HP G62-234DX Keyboard Replacement: 9 단계, 이미지 3개 중 3개
      • Flip the keyboard towards yourself.
      • Do not try to pull it out, as it is still connected to the ribbon cable.
      댓글 쓰기
    5. HP G62-234DX Keyboard Replacement: 10 단계, 이미지 2개 중 1개 HP G62-234DX Keyboard Replacement: 10 단계, 이미지 2개 중 2개
      • Flip up the locking flap using either your fingernail, or a spudger.
      • Remove the ribbon from the ZIF connector.
      댓글 쓰기
    6. HP G62-234DX Keyboard Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the keyboard.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order with the replacement keyboard. Make sure to be careful when reconnecting small or delicate pieces, and don't rush!
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kate Ferland
회원 가입일: 11/01/23
836 평판
안내서 6개를 작성함
UMass Dartmouth, Team 1-1, Petersen Fall 2023 UMass Dartmouth, Team 1-1, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G1
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 39
전체 시간: 672
