주요 콘텐츠로 건너뛰기
HP Mini 1000 LCD Assembly Replacement
필요한 것
  1. HP Mini 1000 LCD Assembly Replacement, Battery: 1 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 LCD Assembly Replacement: 2 단계, 이미지 1/1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    Need a battery and a keyboard.
    valfin.teach - 답글
  3. HP Mini 1000 LCD Assembly Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. HP Mini 1000 LCD Assembly Replacement: 4 단계, 이미지 1/3 HP Mini 1000 LCD Assembly Replacement: 4 단계, 이미지 2/3 HP Mini 1000 LCD Assembly Replacement: 4 단계, 이미지 3/3
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. HP Mini 1000 LCD Assembly Replacement: 5 단계, 이미지 1/1
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. HP Mini 1000 LCD Assembly Replacement: 6 단계, 이미지 1/1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
  7. HP Mini 1000 LCD Assembly Replacement, Hard Drive: 7 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement, Hard Drive: 7 단계, 이미지 2/2
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
  8. HP Mini 1000 LCD Assembly Replacement: 8 단계, 이미지 1/1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
  9. HP Mini 1000 LCD Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
  10. HP Mini 1000 LCD Assembly Replacement: 10 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 10 단계, 이미지 2/2
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
  11. HP Mini 1000 LCD Assembly Replacement, Upper Case: 11 단계, 이미지 1/1
    • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
    • There are three different variations of the covers:
    • The two bottom covers are short in height and are notched to prevent incorrect insertion
    • The upper right cover is taller in height and is notched.
    • The upper left cover is taller in height and is not notched.
  12. HP Mini 1000 LCD Assembly Replacement: 12 단계, 이미지 1/1
    • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
  13. HP Mini 1000 LCD Assembly Replacement: 13 단계, 이미지 1/1
    • Flip the computer over and open the display.
    • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
  14. HP Mini 1000 LCD Assembly Replacement: 14 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 14 단계, 이미지 2/2
    • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
    • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
    • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
  15. HP Mini 1000 LCD Assembly Replacement: 15 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 15 단계, 이미지 2/2
    • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
  16. HP Mini 1000 LCD Assembly Replacement: 16 단계, 이미지 1/1
    • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
    • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
  17. HP Mini 1000 LCD Assembly Replacement: 17 단계, 이미지 1/1
    • Lay the upper case on top of the upper portion of the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
    • Pull the TouchPad ribbon cable out of its socket.
    • Remove the upper case from the HP Mini 1000.
  18. HP Mini 1000 LCD Assembly Replacement, Wi-Fi Board: 18 단계, 이미지 1/1
    • If present, peel the sticker up off the top of the Wi-Fi board to reveal the Wi-Fi antenna connectors.
  19. HP Mini 1000 LCD Assembly Replacement: 19 단계, 이미지 1/3 HP Mini 1000 LCD Assembly Replacement: 19 단계, 이미지 2/3 HP Mini 1000 LCD Assembly Replacement: 19 단계, 이미지 3/3
    • Pry the Wi-Fi antenna connectors (2 total) up off the Wi-Fi board.
    • During reassembly, remember to correctly connect the antenna cables to their respective terminals. The green labeled antenna is connected to the "MAIN" terminal and the white labeled antenna is connected to the "AUX" terminal.
  20. HP Mini 1000 LCD Assembly Replacement: 20 단계, 이미지 1/1
    • Remove the single 3 mm Phillips screw securing Wi-Fi board to the motherboard.
  21. HP Mini 1000 LCD Assembly Replacement: 21 단계, 이미지 1/1
    • Upon removing the Phillips screw that secures the Wi-Fi board to the motherboard, the Wi-Fi board should pop up from its top side nearest the antenna sockets.
    • Grasp the Wi-Fi board and lift it straight away from its socket on the motherboard.
  22. HP Mini 1000 LCD Assembly Replacement, Heat Sink: 22 단계, 이미지 1/1
    • Remove the two 2.5 mm Phillips screws securing the heat sink to the motherboard.
    A magnetic Philips #0 makes this much easier to reassemble than non-magnetic.
    Matthew - 답글
  23. HP Mini 1000 LCD Assembly Replacement: 23 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 23 단계, 이미지 2/2
    • Carefully lift the heat sink off the face of the motherboard and de-route the curved section from next to the fan.
    • Before reinstalling the heat sink, be sure to apply a new layer of thermal paste to the CPU. We have a thermal paste guide that makes it easy.
    • Only apply a new layer of thermal paste to the face of the CPU. The CPU is the large processor located closest to the fan.
    This reassembly needs to precede the installation of the the plastic that covers the fan.
    Matthew - 답글
  24. HP Mini 1000 LCD Assembly Replacement, Display Assembly: 24 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement, Display Assembly: 24 단계, 이미지 2/2
    • If present, carefully remove the large piece of black adhesive film covering the Wi-Fi board.
  25. HP Mini 1000 LCD Assembly Replacement: 25 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 25 단계, 이미지 2/2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the Wi-Fi board.
  26. HP Mini 1000 LCD Assembly Replacement: 26 단계, 이미지 1/1
    • If present, remove the pieces of tape securing the Wi-Fi antenna cables to the upper case.
  27. HP Mini 1000 LCD Assembly Replacement: 27 단계, 이미지 1/1
    • If present, carefully remove the large piece of black adhesive film from the area surrounding the fan.
  28. HP Mini 1000 LCD Assembly Replacement: 28 단계, 이미지 1/1
    • If present, remove the several pieces of black cloth tape securing the cables to the upper case near the fan.
  29. HP Mini 1000 LCD Assembly Replacement: 29 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 29 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect each of the following connectors from their respective sockets:
    • Speaker cable
    • Microphone cable
    • Fan cable
    • Power cable
    • Display data cable
    • Push the connectors out of their sockets parallel to the face of the motherboard toward the display assembly. Do not lift up on the cables as you disconnect them, especially the display data cable, as their sockets may break off the motherboard.
  30. HP Mini 1000 LCD Assembly Replacement: 30 단계, 이미지 1/1
    • If present, peel back the strip of white cloth tape highlighted in red to reveal a display screw.
  31. HP Mini 1000 LCD Assembly Replacement: 31 단계, 이미지 1/1
    • Remove the single 5 mm Phillips screw securing the right display hinge to the lower case.
  32. HP Mini 1000 LCD Assembly Replacement: 32 단계, 이미지 1/1
    • Remove the two 5 mm Phillips screws securing the left display hinge to the lower case.
  33. HP Mini 1000 LCD Assembly Replacement: 33 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 33 단계, 이미지 2/2
    • Lift the display out of the lower case, minding any cables that may get caught.
  34. HP Mini 1000 LCD Assembly Replacement, Speaker Grill: 34 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement, Speaker Grill: 34 단계, 이미지 2/2
    • Use the edge of a plastic opening tool to pry the left side of the speaker grill away from the display assembly.
    • Be careful not to apply too much pressure to the display glass.
  35. HP Mini 1000 LCD Assembly Replacement: 35 단계, 이미지 1/1
    • Continue prying along the center of the speaker grill.
  36. HP Mini 1000 LCD Assembly Replacement: 36 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 36 단계, 이미지 2/2
    • Pry the right side of the speaker grill away from the display assembly.
  37. HP Mini 1000 LCD Assembly Replacement: 37 단계, 이미지 1/1
    • Remove the speaker grill.
  38. HP Mini 1000 LCD Assembly Replacement, Speaker Assembly: 38 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement, Speaker Assembly: 38 단계, 이미지 2/2
    • Remove the two 4.5 mm Phillips screws securing the speaker assembly to the display.
    • Remove the speaker assembly.
  39. HP Mini 1000 LCD Assembly Replacement, Front Display Bezel: 39 단계, 이미지 1/1
    • In the following steps you will pry the front display bezel off the rear section of the display. The locations of the retaining clips are highlighted in red.
  40. HP Mini 1000 LCD Assembly Replacement: 40 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 40 단계, 이미지 2/2
    • Use the edge of a plastic opening tool to pry up the front display bezel near the right display hinge.
  41. HP Mini 1000 LCD Assembly Replacement: 41 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 41 단계, 이미지 2/2
    • Continue prying to release the clips attaching the front display bezel to the right side of the display's rear section.
  42. HP Mini 1000 LCD Assembly Replacement: 42 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 42 단계, 이미지 2/2
    • Continue prying up the front display bezel along the top edge of the display.
  43. HP Mini 1000 LCD Assembly Replacement: 43 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 43 단계, 이미지 2/2
    • Finally, use a plastic opening tool to release the retaining clips along the left side and bottom left corner of the display.
  44. HP Mini 1000 LCD Assembly Replacement: 44 단계, 이미지 1/1
    • Remove the front display bezel from the rest of the display assembly.
  45. HP Mini 1000 LCD Assembly Replacement, Camera Board Cable: 45 단계, 이미지 1/1
    • Use the sharp end of a spudger to flip up the plastic flap that rests on top of the camera board cable ZIF socket.
  46. HP Mini 1000 LCD Assembly Replacement: 46 단계, 이미지 1/2 HP Mini 1000 LCD Assembly Replacement: 46 단계, 이미지 2/2
    • Use your fingernail or the sharp end of a spudger to flip up the retaining flap on the camera board cable ZIF socket.
    • Pull the camera board ribbon cable out of its socket.
  47. HP Mini 1000 LCD Assembly Replacement, LCD Assembly: 47 단계, 이미지 1/1
    • If present, peel back the three pieces of cloth tape highlighted in red.
    • If present, remove the small strip of black cloth tape highlighted in orange.
  48. HP Mini 1000 LCD Assembly Replacement: 48 단계, 이미지 1/1
    • Remove the nine 3 mm Phillips screws securing the LCD to the rear display bezel.
  49. HP Mini 1000 LCD Assembly Replacement: 49 단계, 이미지 1/1
    • Lift the lower right corner of the LCD enough to de-route the antenna cables from its frame.
  50. HP Mini 1000 LCD Assembly Replacement: 50 단계, 이미지 1/1
    • Lift the left edge of the LCD out of the rear display bezel and de-route the cables from the brackets along the left side.
  51. HP Mini 1000 LCD Assembly Replacement: 51 단계, 이미지 1/1
    • Remove the LCD from the rear display bezel.
    • If your new LCD has no brackets included, swap the brackets from the old LCD to your new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,782 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Do we really need to take that much off to just replace the screen? I've never done this before and I have no idea what is going on.
Lycan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 12
전체 시간: 8,977
