주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Mini 110-1046NR Keyboard Replacement
필요한 것
  1. HP Mini 110-1046NR Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Mini 110-1046NR Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Mini 110-1046NR Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
    댓글 쓰기
  2. HP Mini 110-1046NR Keyboard Replacement, Keyboard: 2 단계, 이미지 2개 중 1개 HP Mini 110-1046NR Keyboard Replacement, Keyboard: 2 단계, 이미지 2개 중 2개
    • With the screen closed, turn your netbook around so that the battery slot is facing you.
    • Remove the three 2.9mm screws in the battery slot.
    • This step can be made easier by using a magnetic screwdriver.
    댓글 쓰기
  3. HP Mini 110-1046NR Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Mini 110-1046NR Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Mini 110-1046NR Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the netbook upright, and open the screen as far as it will go.
    • Pry up the keyboard from the middle of the top edge.
    • Insert the flat end of the spudger between middle of the the top edge of the keyboard and the plastic frame behind it.
    • Pry the keyboard up until it pops out or until you can grab it with your fingers, and then pull gently until it pops out on both sides.
    • Do not pull the keyboard out immediately - there is a potentially fragile ribbon cable that attaches to the motherboard behind the keyboard.
    댓글 쓰기
  4. HP Mini 110-1046NR Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HP Mini 110-1046NR Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HP Mini 110-1046NR Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Flip the keyboard over (toward you) by pivoting it about the lower edge, and lay it upside down on top of the touchpad area to reveal the ribbon cable.
    • Lightly pull up on the black tab on top of the keyboard ribbon cable until it hinges toward you and releases the ribbon cable end.
    • Pull the ribbon cable backward and out of the receptacle. This should not require any effort.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Amos Hine
회원 가입일: 10/18/13
1,275 평판
안내서 7개를 작성함
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013 회원
CLEM-BENSON-F13S14G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 66
전체 시간: 7,055
