주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Mini 210 CMOS Battery Replacement
필요한 것
  1. HP Mini 210 CMOS Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Mini 210 CMOS Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    댓글 쓰기
  2. HP Mini 210 CMOS Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery out from the netbook.
    댓글 쓰기
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: 3 단계, 이미지 1개 중 1개
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    댓글 쓰기
  4. HP Mini 210 CMOS Battery Replacement: 4 단계, 이미지 1개 중 1개
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    댓글 쓰기
  5. HP Mini 210 CMOS Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the back case off from the front edge.
    댓글 쓰기
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 1개 중 1개
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
    댓글 쓰기
  7. HP Mini 210 CMOS Battery Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Slowly peel back the black adhesive ribbon with tweezers.
    댓글 쓰기
  8. HP Mini 210 CMOS Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Pry the CMOS battery out with a plastic opening tool.
    댓글 쓰기
  9. HP Mini 210 CMOS Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Heather Freed
회원 가입일: 10/06/12
723 평판
안내서 8개를 작성함
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G17
3 회원들
안내서 8개를 작성함
2가이드 댓글
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - 답글 공유
Very good tut. Now my HP Mini 210 can get the right time xD
Byte Core - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 84
전체 시간: 17,099
