주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Mini 210 Keyboard Replacement
필요한 것
    1. HP Mini 210 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Mini 210 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      댓글 쓰기
    2. HP Mini 210 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the battery out from the netbook.
      댓글 쓰기
    1. HP Mini 210 Keyboard Replacement, Disassembling HP Mini 210 Back Case: 3 단계, 이미지 1개 중 1개
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      댓글 쓰기
    2. HP Mini 210 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      댓글 쓰기
    3. HP Mini 210 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the back case off from the front edge.
      댓글 쓰기
    1. HP Mini 210 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 HP Mini 210 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 HP Mini 210 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
      • Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
      댓글 쓰기
    2. HP Mini 210 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 HP Mini 210 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
      • Once you have removed the screws, flip the netbook over so that the keyboard is now facing upwards. Open the screen as far back as the netbook allows.
      • Using a prying tool, lift upwards and remove the plastic casing that covers the spaces around the keys of the keyboard.
      • Be careful when removing the plastic casing.
      댓글 쓰기
    3. HP Mini 210 Keyboard Replacement: 8 단계, 이미지 3개 중 1개 HP Mini 210 Keyboard Replacement: 8 단계, 이미지 3개 중 2개 HP Mini 210 Keyboard Replacement: 8 단계, 이미지 3개 중 3개
      • After removing the plastic casing surrounding the keys, carefully lift the full keyboard from the netbook using a plastic opening tool.
      • Do not yank the keyboard out. The keyboard is attached to the netbook through a ribbon cable, which needs to remain undamaged in order for the new keyboard to properly connect with the netbook.
      댓글 쓰기
    4. HP Mini 210 Keyboard Replacement: 9 단계, 이미지 3개 중 1개 HP Mini 210 Keyboard Replacement: 9 단계, 이미지 3개 중 2개 HP Mini 210 Keyboard Replacement: 9 단계, 이미지 3개 중 3개
      • Be very gentle with the ZIF connector! It is designed to be locked into the motherboard, so make sure you lift the retaining latch before attempting to disconnect it.
      • Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
      • Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Heather Freed
회원 가입일: 10/06/12
723 평판
안내서 8개를 작성함
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G17
3 회원들
안내서 94개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 50
전체 시간: 15,749
