주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Mini 210-2070NR Keyboard Replacement
필요한 것
  1. HP Mini 210-2070NR Keyboard Replacement, Battery and Service Access Cover: 1 단계, 이미지 1개 중 1개
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
    댓글 쓰기
  2. HP Mini 210-2070NR Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP Mini 210-2070NR Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP Mini 210-2070NR Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
    댓글 쓰기
  3. HP Mini 210-2070NR Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Mini 210-2070NR Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Mini 210-2070NR Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
    댓글 쓰기
  4. HP Mini 210-2070NR Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Orient the computer as shown in the picture.
    댓글 쓰기
  5. HP Mini 210-2070NR Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 HP Mini 210-2070NR Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
    • Each of the screws are labeled with small keyboards next to them.
    • Flip the computer over so that the front is facing you.
    댓글 쓰기
  6. HP Mini 210-2070NR Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP Mini 210-2070NR Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP Mini 210-2070NR Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
    • Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
    • Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
    • There is a cable connecting the keyboard to the laptop, so do not attempt to fully remove the keyboard yet or you will damage your device.
    댓글 쓰기
  7. HP Mini 210-2070NR Keyboard Replacement: 7 단계, 이미지 2개 중 1개 HP Mini 210-2070NR Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
    • Pull the keyboard cable out of its socket to disconnect it.
    댓글 쓰기
  8. HP Mini 210-2070NR Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard by lifting it away from the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Sean Kuster
회원 가입일: 10/05/12
91 평판
안내서 3개를 작성함
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G23
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 26
전체 시간: 2,016
