주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement
필요한 것
  1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Battery and Service Access Cover: 1 단계, 이미지 1개 중 1개
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
    댓글 쓰기
  2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 2 단계, 이미지 3개 중 1개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 2 단계, 이미지 3개 중 2개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 2 단계, 이미지 3개 중 3개
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
    댓글 쓰기
  3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 3 단계, 이미지 3개 중 1개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 3 단계, 이미지 3개 중 2개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
    댓글 쓰기
  4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 4 단계, 이미지 1개 중 1개
    • Orient the computer as shown in the picture.
    댓글 쓰기
  5. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): 5 단계, 이미지 2개 중 1개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): 5 단계, 이미지 2개 중 2개
    • Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
    댓글 쓰기
  6. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 6 단계, 이미지 3개 중 1개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 6 단계, 이미지 3개 중 2개 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
    • There should be two black cables, one labeled with a white sticker, connected to the module.
    댓글 쓰기
  7. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
    • The card should tilt up away from the laptop at an angle after removing the screws.
    댓글 쓰기
  8. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the Wi-Fi card by gently pulling it out of its slot at an angle.
    • Potential for device damage: Be sure to pull gently and at an angle away from you. If the card is pulled straight up, there is a chance it could break or bend.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Taylor
회원 가입일: 10/05/12
116 평판
안내서 1개를 작성함
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G23
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 37
전체 시간: 1,565
