주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Mini 311 Keyboard Replacement
필요한 것
  1. HP Mini 311 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Mini 311 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Mini 311 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    댓글 쓰기
  2. HP Mini 311 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Mini 311 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery away from the device to remove.
    댓글 쓰기
  3. HP Mini 311 Keyboard Replacement, Memory Shield: 3 단계, 이미지 1개 중 1개
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
    댓글 쓰기
  4. HP Mini 311 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Mini 311 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the memory shield up and remove from the laptop.
    댓글 쓰기
  5. HP Mini 311 Keyboard Replacement, Hard Drive: 5 단계, 이미지 3개 중 1개 HP Mini 311 Keyboard Replacement, Hard Drive: 5 단계, 이미지 3개 중 2개 HP Mini 311 Keyboard Replacement, Hard Drive: 5 단계, 이미지 3개 중 3개
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
    댓글 쓰기
  6. HP Mini 311 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP Mini 311 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP Mini 311 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
    댓글 쓰기
  7. HP Mini 311 Keyboard Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
    댓글 쓰기
  8. HP Mini 311 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Open the laptop so that the screen and front of the keyboard are both facing the ground.
    • Push on the opening on the back side of the device until the keyboard partially pops out.
    • This opening is located where the original hard drive was set.
    댓글 쓰기
  9. HP Mini 311 Keyboard Replacement: 9 단계, 이미지 3개 중 1개 HP Mini 311 Keyboard Replacement: 9 단계, 이미지 3개 중 2개 HP Mini 311 Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Flip the device around and orient it so that the screen and keyboard are facing you.
    • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
    • The right side of the keyboard should be unattached.
    • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
    댓글 쓰기
  10. HP Mini 311 Keyboard Replacement: 10 단계, 이미지 3개 중 1개 HP Mini 311 Keyboard Replacement: 10 단계, 이미지 3개 중 2개 HP Mini 311 Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Christian Santoyo
회원 가입일: 01/31/13
495 평판
안내서 6개를 작성함
Cal Poly, Team 20-4, Maness Winter 2013 Cal Poly, Team 20-4, Maness Winter 2013 회원
CPSU-MANESS-W13S20G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 27
전체 시간: 2,971
