주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP OfficeJet 4650 Power Button Replacement
필요한 것
    1. HP OfficeJet 4650 Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 3개
      • Open the cartridge access door by putting one hand on the grooves of each side and pulling up.
      댓글 쓰기
    2. HP OfficeJet 4650 Power Button Replacement: 2 단계, 이미지 2개 중 1개 HP OfficeJet 4650 Power Button Replacement: 2 단계, 이미지 2개 중 2개
      • Using the 2.0 mm hex screwdriver, remove the 14 mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
      댓글 쓰기
    3. HP OfficeJet 4650 Power Button Replacement: 3 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Power Button Replacement: 3 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Power Button Replacement: 3 단계, 이미지 3개 중 3개
      • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
      • Push the panel upward to remove it from the printer.
      • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
      댓글 쓰기
    4. HP OfficeJet 4650 Power Button Replacement: 4 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Power Button Replacement: 4 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Power Button Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
      댓글 쓰기
    5. HP OfficeJet 4650 Power Button Replacement: 5 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Power Button Replacement: 5 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Power Button Replacement: 5 단계, 이미지 3개 중 3개
      • Using the Torx T6 hex screwdriver, remove the 7.0mm screw that binds the front cover to the printer body by turning the screw counterclockwise.
      댓글 쓰기
    6. HP OfficeJet 4650 Power Button Replacement: 6 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Power Button Replacement: 6 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Power Button Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from button circuit board.
      댓글 쓰기
    7. HP OfficeJet 4650 Power Button Replacement: 7 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Power Button Replacement: 7 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Power Button Replacement: 7 단계, 이미지 3개 중 3개
      • Pop the button off from the black cover by using your finger tip to bring it up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Stephanie Carpintero
회원 가입일: 01/24/18
1,021 평판
안내서 5개를 작성함
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G6
3 회원들
안내서 30개를 작성함
6가이드 댓글
Does this fix the printer not turning on?
cindim - 답글 공유
Where can I purchase the replacement Power Button? What is the part number?
Mort Rosenberg - 답글 공유
Is it possible to bypass the malfunctioning power button, so the printer is on whenever it is plugged in? If so, how?
Ron Sela - 답글 공유
Jack Farr
Jack Farr - 답글 공유
Bonjour,
Ou peut on acheter l'écran tactile HP Officejet 4650 ???
Georges N'GUELA - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 44
전체 시간: 4,334
