주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP OfficeJet 4650 Touchscreen Replacement
필요한 것
    1. HP OfficeJet 4650 Touchscreen Replacement, Touchscreen: 1 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Touchscreen Replacement, Touchscreen: 1 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Touchscreen Replacement, Touchscreen: 1 단계, 이미지 3개 중 3개
      • Open the cartridge access door by using putting one hand on the grooves of each side and pulling up.
      댓글 쓰기
    2. HP OfficeJet 4650 Touchscreen Replacement: 2 단계, 이미지 2개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 2 단계, 이미지 2개 중 2개
      • Using the 2.0mm screwdriver, remove the 14mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
      댓글 쓰기
    3. HP OfficeJet 4650 Touchscreen Replacement: 3 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 3 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Touchscreen Replacement: 3 단계, 이미지 3개 중 3개
      • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
      • Push the panel upward to remove it from the printer.
      • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
      댓글 쓰기
    4. HP OfficeJet 4650 Touchscreen Replacement: 4 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 4 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Touchscreen Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
      댓글 쓰기
    5. HP OfficeJet 4650 Touchscreen Replacement: 5 단계, 이미지 2개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the other connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
      댓글 쓰기
    6. HP OfficeJet 4650 Touchscreen Replacement: 6 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 6 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Touchscreen Replacement: 6 단계, 이미지 3개 중 3개
      • Unclip the yellow connector by lifting up the grey piece with your finger.
      • The yellow connector will pop right up when the grey piece is unclipped.
      댓글 쓰기
    7. HP OfficeJet 4650 Touchscreen Replacement: 7 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 7 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Touchscreen Replacement: 7 단계, 이미지 3개 중 3개
      댓글 쓰기
    8. HP OfficeJet 4650 Touchscreen Replacement: 8 단계, 이미지 2개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 8 단계, 이미지 2개 중 2개
      • Using the Torx T6 hex screwdriver, remove the 7.0mm screws that bind the screen to the printer body by turning the screws counterclockwise.
      • Using the Torx T6 hex screwdriver, remove the 7.0mm screws that bind the green circuit board to the screen by turning the screws counterclockwise.
      댓글 쓰기
    9. HP OfficeJet 4650 Touchscreen Replacement: 9 단계, 이미지 3개 중 1개 HP OfficeJet 4650 Touchscreen Replacement: 9 단계, 이미지 3개 중 2개 HP OfficeJet 4650 Touchscreen Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the circuit board by lifting it off the screen in order to get the screen on its own.
      • Pull the screen off the front panel cover.
      • The clear plastics pieces will easily fall off when the screen is lifted off. Do not lose them.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Stephanie Carpintero
회원 가입일: 01/24/18
1,021 평판
안내서 5개를 작성함
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G6
3 회원들
안내서 10개를 작성함
2가이드 댓글
Where do I buy the replacement screen
Aadil Hussain - 답글 공유
Where can you buy a replacement screen
William Joseph Adduci - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 42
전체 시간: 3,515
