주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Officejet Pro 6835 Printhead Replacement
필요한 것
    1. HP Officejet Pro 6835 Printhead Replacement, HP Officejet Pro 6835 Cover Disassembly: 1 단계, 이미지 1개 중 1개
      • Open the main lid as far as it will go.
      • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
      • Open the lid further.
      댓글 쓰기
    2. HP Officejet Pro 6835 Printhead Replacement: 2 단계, 이미지 3개 중 1개 HP Officejet Pro 6835 Printhead Replacement: 2 단계, 이미지 3개 중 2개 HP Officejet Pro 6835 Printhead Replacement: 2 단계, 이미지 3개 중 3개
      • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
      • The two screws above the screen assembly are deep so you may need a long screwdriver.
      댓글 쓰기
    3. HP Officejet Pro 6835 Printhead Replacement: 3 단계, 이미지 1개 중 1개
      • Grab the main cover and lift it up slightly.
      • Do not pull too hard—there is a cable connecting the cover to the printer.
      댓글 쓰기
    4. HP Officejet Pro 6835 Printhead Replacement: 4 단계, 이미지 2개 중 1개 HP Officejet Pro 6835 Printhead Replacement: 4 단계, 이미지 2개 중 2개
      • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
      댓글 쓰기
    1. HP Officejet Pro 6835 Printhead Replacement, Printhead: 5 단계, 이미지 2개 중 1개 HP Officejet Pro 6835 Printhead Replacement, Printhead: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using tweezers, pinch the top of the spring located on the right side of the printhead.
      • Pull the spring up and around the hook of the carriage to remove the spring from the printhead.
      • Use the same procedure to remove the left spring.
      • The springs may fly out of the printer once you remove them.
      댓글 쓰기
    2. HP Officejet Pro 6835 Printhead Replacement: 6 단계, 이미지 3개 중 1개 HP Officejet Pro 6835 Printhead Replacement: 6 단계, 이미지 3개 중 2개 HP Officejet Pro 6835 Printhead Replacement: 6 단계, 이미지 3개 중 3개
      • Pinch the left most white cable located on the back of the printhead with your tweezers.
      • Pull the cable to remove it from the printhead.
      • Continue this process to remove all three white cable from the printhead.
      댓글 쓰기
    3. HP Officejet Pro 6835 Printhead Replacement: 7 단계, 이미지 3개 중 1개 HP Officejet Pro 6835 Printhead Replacement: 7 단계, 이미지 3개 중 2개 HP Officejet Pro 6835 Printhead Replacement: 7 단계, 이미지 3개 중 3개
      • Lift the printhead off the printer to expose the last white cable.
      • Pinch the the last cable with the tweezers.
      • Pull the cable to disconnect it from the printhead.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dimitri Charitou
회원 가입일: 01/24/18
519 평판
안내서 2개를 작성함
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G4
4 회원들
안내서 72개를 작성함
5가이드 댓글
The printhead replacement went smooth however, the printer will not now print and the print carriage slams into home position like it is trying to break through the side of the printer. What could be the problem?
Michael Cook - 답글 공유
The location tape is upside down
flaherty_claire - 답글 공유
Thank you very much for this guide.
I bought a replacement print head from Amazon.
There were some remanufactured on eBay, but the Amazon had some reviews (I know, I know, they’re probably fake).
As a suggestion, on the printhead cables, make sure you pull out the RIBBON and don’t pull the connector. It’s soldered to the board.
It’s easier to just remove the plastic ribbon that guides the print head. Push on the metal frame to ease it out, and then the printhead can be pulled out.
In that way, access to the ribbon connectors is much easier.
My printer had not been working for over 4 years. So, it was not wanting to pull paper. Gave it a thorough cleaning and voilà.
It took a few tries. Got my ink from Amazon, from a company called DoubleD. It works just fine.
Printhead: https://www.amazon.com/dp/B08BF8YGG6?psc...
Ink: https://www.amazon.com/dp/B086MSDWFH?psc...
Thanks again for the guide. Life saver, and the printer was rescued from going to the recycler.
Eyvind Mondragon - 답글 공유
which of the 4 ribbons is the location tape
Dave Glotzbach - 답글 공유
I replaced the printhead because it was not printing blue. It was coming out pink. It was not printing green properly. After replacement it still acting the same. Any ideas?
Phillip - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 90
전체 시간: 18,105
