주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP PSC 2355 Button Panel Replacement
필요한 것
    1. HP PSC 2355 Button Panel Replacement, Scanner Lid: 1 단계, 이미지 1개 중 1개
      • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
      댓글 쓰기
    2. HP PSC 2355 Button Panel Replacement: 2 단계, 이미지 1개 중 1개
      • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
      댓글 쓰기
    1. HP PSC 2355 Button Panel Replacement, Button Panel: 3 단계, 이미지 1개 중 1개
      • Once you have removed the scanner lid, locate the finger notch on inside the top left half of the bezel (control) panel.
      댓글 쓰기
    2. HP PSC 2355 Button Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Place your index finger in the notch and lift up to unsnap the panel.
      • Set panel cover aside.
      댓글 쓰기
    3. HP PSC 2355 Button Panel Replacement: 5 단계, 이미지 1개 중 1개
      • Use a T9 torx screwdriver to remove the 0.9 cm screw.
      댓글 쓰기
    4. HP PSC 2355 Button Panel Replacement: 6 단계, 이미지 1개 중 1개
      • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
      댓글 쓰기
    5. HP PSC 2355 Button Panel Replacement: 7 단계, 이미지 1개 중 1개
      • Disconnect the white ribbon cable by grasping it between your thumb and index finger.
      • Gently pull to release the ribbon from the green circuit board
      댓글 쓰기
    6. HP PSC 2355 Button Panel Replacement: 8 단계, 이미지 1개 중 1개
      • Next, use the flat end of a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
      • The entire button panel should now be completely disconnected from the printer.
      댓글 쓰기
    7. HP PSC 2355 Button Panel Replacement: 9 단계, 이미지 1개 중 1개
      • Lay the panel on a flat surface with the backside facing up.
      • Using a T9 torx screwdriver, remove all six 0.7 cm silver screws from the off-white plastic panel.
      댓글 쓰기
    8. HP PSC 2355 Button Panel Replacement: 10 단계, 이미지 1개 중 1개
      • Gently lift the button panel off the plastic backing with rubber button mat.
      댓글 쓰기
    9. HP PSC 2355 Button Panel Replacement: 11 단계, 이미지 1개 중 1개
      • Be careful not to lift out and lose the two clear plastic panel separators (these are not fastened to the panel but can easily fall out of the panel if tilted). These are two small plastic parts that sit near the top right and left portions of the panel.
      • Insert your new button panel. To reassemble your printer, follow these instructions in reverse order.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Patricia
회원 가입일: 01/23/14
143 평판
안내서 1개를 작성함
TheFixers TheFixers 회원
Community
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 1,317
