주요 콘텐츠로 건너뛰기
HP Pavilion 14-bk061st Heat Sink Replacement
필요한 것
  1. HP Pavilion 14-bk061st Heat Sink Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Heat Sink Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Heat Sink Replacement: 2 단계, 이미지 1개 중 1개
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Heat Sink Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Heat Sink Replacement, Heat Sink: 4 단계, 이미지 2개 중 1개 HP Pavilion 14-bk061st Heat Sink Replacement, Heat Sink: 4 단계, 이미지 2개 중 2개
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  5. HP Pavilion 14-bk061st Heat Sink Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stefano Lo Re
회원 가입일: 01/22/20
382 평판
안내서 3개를 작성함
York University, Team S8-G3, Turner Winter 2020 York University, Team S8-G3, Turner Winter 2020 회원
YORK-TURNER-W20S8G3
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 344
