주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 14-v062us Keyboard Replacement
필요한 것
  1. HP Pavilion 14-v062us Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power laptop off and make sure it is not plugged into charger
    • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
    댓글 쓰기
  2. HP Pavilion 14-v062us Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery upwards and out from the laptop
    댓글 쓰기
  3. HP Pavilion 14-v062us Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Remove rectangular rubber tops with a spudger
    • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
    • Remove plastic edge covering with the blue plastic opening tool.
    • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
    댓글 쓰기
  4. HP Pavilion 14-v062us Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use Phillips screwdriver #1
    • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
    • Remove the three 7.14 mm PH#1 screws.
    • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
    댓글 쓰기
  5. HP Pavilion 14-v062us Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove disc tray
    • Locate screw within computer that is inside of where the disc tray was
    • Using a Phillips #1 screwdriver, unscrew the screw
    • Set laptop down and open laptop so the keyboard is facing you
    댓글 쓰기
  6. HP Pavilion 14-v062us Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
    • Pry until you are able to lift entire face and keyboard
    • Only cables should be connecting it underneath
    댓글 쓰기
  7. HP Pavilion 14-v062us Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect/ unplug cables using plastic opening tool.
    • Separate the keyboard panel from the laptop with your hands.
    • Turn around the laptop and lay it flat.
    댓글 쓰기
  8. HP Pavilion 14-v062us Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
    • Only use a metal spudger as a last resort
    댓글 쓰기
  9. HP Pavilion 14-v062us Keyboard Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Keyboard Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Flora Peterson
회원 가입일: 09/21/17
233 평판
안내서 2개를 작성함
2가이드 댓글
Thank you so much, this guide is very helpful.
Rodolfo Trujillo - 답글 공유
Thank you for the guide. It was very helpful!
dmitryp80 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 2,387
