소개
This guide shows you how to replace the built-in laptop keyboard assembly for the HP Pavilion 15-cc561st. This can fix issues such as stuck keys, unresponsive keys, missing keys, etc.
필요한 것
Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
Two 5.6 mm screws
Three 5.8 mm screws
Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
Use a Phillips #0 screwdriver to remove the four 3.0 mm screws that secure the heat sink.
Gently release the slider of the ZIF connector that the USB port board is connected to.
Gently lift the Flat Flexible Cable away from the ZIF connector to disconnect the cable from the USB port board.
Disconnect the WLAN antenna cables from the terminals on the WLAN module:
Cable labeled "1/AUX" which connects to the "Aux" terminal
Cable labeled "2/MAIN" which connects to the "Main" terminal
Remove the bundled cable connector from the terminal by pulling it horizontally out of its socket.
Use a Phillips #00 screwdriver to remove the 2.22 mm silver screw that secures the power button PCB.
Lift to remove the power button PCB.
