주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion DV2160BR Keyboard Replacement
필요한 것
    1. HP Pavilion DV2160BR Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Start with the bottom of the laptop facing up.
      댓글 쓰기
    2. HP Pavilion DV2160BR Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion DV2160BR Keyboard Replacement: 2 단계, 이미지 2개 중 2개
      • Locate the battery compartment at the rear of the device.
      • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
      댓글 쓰기
    1. HP Pavilion DV2160BR Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
      • Unscrew the 5 screws along the top edge of the laptop’s back panel and inside the battery compartment.
      • The two screws inside the battery compartment are 5 mm Phillips #1.
      • The three screws outside the battery compartment are 9 mm Phillips #1.
      댓글 쓰기
    2. HP Pavilion DV2160BR Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion DV2160BR Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion DV2160BR Keyboard Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the three 6 mm Phillips #1 screws that are marked by a keyboard symbol. These screws are holding in the keyboard itself.
      댓글 쓰기
    3. HP Pavilion DV2160BR Keyboard Replacement: 5 단계, 이미지 1개 중 1개
      • Flip the laptop over and open the lid.
      댓글 쓰기
    4. HP Pavilion DV2160BR Keyboard Replacement: 6 단계, 이미지 1개 중 1개
      • Using a blue plastic opening tool, remove the bezel by sliding the tool along the edges.
      • The bezel is held in place by plastic tabs, which you will hear snapping out of place as you slide the plastic opener tool.
      • You don't need to take the bezel all the way off the device, and shouldn't since it it connected to the laptop by two cables.
      댓글 쓰기
    5. HP Pavilion DV2160BR Keyboard Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the keyboard from the device, starting from the top sides and pulling it away from the bottom end gently.
      • The keyboard is still connected by a cable, so do not pull it too quickly as it could become damaged.
      댓글 쓰기
    6. HP Pavilion DV2160BR Keyboard Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the old keyboard by gently unplugging the ribbon cable
      • Prepare the new keyboard and connect it to the laptop via the ribbon cable
      • After reconnecting the ribbon cable, ensure it is securely fastened and the connector is properly locked.
      • Carefully reassemble the keyboard into its housing, making sure all tabs are aligned. Reattach the back panel and screws, then power on the laptop to test the new keyboard.
      • Confirm that all keys are functioning correctly and the keyboard is securely in place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Shannon
회원 가입일: 04/11/13
55 평판
안내서 6개를 작성함
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G66
3 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 16
전체 시간: 1,206
