주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion G6 Screen Replacement
필요한 것
  1. HP Pavilion G6  Screen Replacement, Remove the battery: 1 단계, 이미지 3개 중 1개 HP Pavilion G6  Screen Replacement, Remove the battery: 1 단계, 이미지 3개 중 2개 HP Pavilion G6  Screen Replacement, Remove the battery: 1 단계, 이미지 3개 중 3개
    • Close the laptop and flip it over.
    • Slide the release pin to pop the battery.
    • Remove the battery completely.
    댓글 쓰기
  2. HP Pavilion G6  Screen Replacement, Remove the screw covers: 2 단계, 이미지 3개 중 1개 HP Pavilion G6  Screen Replacement, Remove the screw covers: 2 단계, 이미지 3개 중 2개 HP Pavilion G6  Screen Replacement, Remove the screw covers: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Open the laptop and locate the screw covers.
    • Remove the screw covers at the bottom of the screen with tweezers.
    • Keep them somewhere safe as you will need to stick them back after the repair.
    댓글 쓰기
  3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: 3 단계, 이미지 3개 중 1개 HP Pavilion G6  Screen Replacement, Remove the plastic frame: 3 단계, 이미지 3개 중 2개 HP Pavilion G6  Screen Replacement, Remove the plastic frame: 3 단계, 이미지 3개 중 3개
    • Unscrew the exposed 2 x Philips screws and set them aside.
    • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
    • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
    • Finally, remove the frame.
    댓글 쓰기
  4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: 4 단계, 이미지 3개 중 1개 HP Pavilion G6  Screen Replacement, Release the screen from the frame: 4 단계, 이미지 3개 중 2개 HP Pavilion G6  Screen Replacement, Release the screen from the frame: 4 단계, 이미지 3개 중 3개
    • Remove the black Philips screw from the top on each side.
    • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
    • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
    댓글 쓰기
  5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: 5 단계, 이미지 3개 중 1개 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: 5 단계, 이미지 3개 중 2개 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: 5 단계, 이미지 3개 중 3개
    • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
    • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
    • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
    댓글 쓰기
  6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: 6 단계, 이미지 2개 중 1개 HP Pavilion G6  Screen Replacement, Check the model number before ordering: 6 단계, 이미지 2개 중 2개
    • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
    • Check the cable connector to make sure you order the correct screen with the correct number of pins.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
honakrisi
회원 가입일: 01/28/20
4,155 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 59
전체 시간: 2,171
