주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
필요한 것
    1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
      댓글 쓰기
    1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
      • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
      • Pull off the plastic cover of the laptop.
      댓글 쓰기
    2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
      • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
      • This step allows the top plate to be removed from the body of the laptop in the following step.
      댓글 쓰기
    3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Use a spudger to lift the keyboard plate off of the base of the computer.
      • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
      댓글 쓰기
    4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the screws connecting the keyboard to the underside of the plate
      • Detach the ribbon wire connecting the keyboard to the hardware.
      • This picture shows the underside of the keyboard after it is removed from the laptop.
      댓글 쓰기
    5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
      • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Robert Hemphill
회원 가입일: 01/22/15
278 평판
안내서 2개를 작성함
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015 회원
CPSU-MANESS-W15S21G22
4 회원들
안내서 12개를 작성함
1가이드 댓글
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 33
전체 시간: 2,045
