주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Photosmart c3180 Scanner Bulb Replacement
필요한 것
    1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: 1 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: 1 단계, 이미지 2개 중 2개
      • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
      • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
      • Remove the two T10 12mm Torx screws from the left side panel.
      댓글 쓰기
    2. HP Photosmart c3180 Scanner Bulb Replacement: 2 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 2 단계, 이미지 2개 중 2개
      • Firmly pull the the back of the side panel until it separates from the body of the printer.
      • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
      댓글 쓰기
    3. HP Photosmart c3180 Scanner Bulb Replacement: 3 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 3 단계, 이미지 2개 중 2개
      • Rotate the printer 90 degrees clockwise.
      • Grasp the paper tray and rotate it down.
      • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
      댓글 쓰기
    4. HP Photosmart c3180 Scanner Bulb Replacement: 4 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the two T10 12 mm Torx screws.
      • Grasp both sides of the side panel and pull it forward to remove the panel.
      댓글 쓰기
    5. HP Photosmart c3180 Scanner Bulb Replacement: 5 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 5 단계, 이미지 2개 중 2개
      • Rotate the printer 90 degrees counter clockwise.
      • Lift the scanner lid to expose the scanner glass.
      댓글 쓰기
    6. HP Photosmart c3180 Scanner Bulb Replacement: 6 단계, 이미지 1개 중 1개
      • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
      댓글 쓰기
    7. HP Photosmart c3180 Scanner Bulb Replacement: 7 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 7 단계, 이미지 2개 중 2개
      • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
      • Remove the front panel by grasping its front and pulling away from the printer.
      댓글 쓰기
    8. HP Photosmart c3180 Scanner Bulb Replacement: 8 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the cable connecting the top panel of the printer to the power button assembly.
      댓글 쓰기
    9. HP Photosmart c3180 Scanner Bulb Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully lift the top panel of the printer away from the printer body.
      댓글 쓰기
    1. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: 10 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: 10 단계, 이미지 2개 중 2개
      • Set aside the top panel of the printer.
      • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
      댓글 쓰기
    2. HP Photosmart c3180 Scanner Bulb Replacement: 11 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 11 단계, 이미지 2개 중 2개
      • Flip the scanner carriage over to expose the connectors on the bottom.
      • Carefully remove the small cable from the connector.
      • Carefully remove the large cable from the connector.
      댓글 쓰기
    3. HP Photosmart c3180 Scanner Bulb Replacement: 12 단계, 이미지 2개 중 1개 HP Photosmart c3180 Scanner Bulb Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the scanner carriage from the scanner tray and flip it upside down.
      • Remove the two T10 12mm Torx screws.
      • Remove the scanner carriage from the scanner bulb.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jim
회원 가입일: 10/06/11
1,638 평판
안내서 10개를 작성함
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 회원
CPSU-MANESS-F11S20G30
4 회원들
안내서 45개를 작성함
1가이드 댓글
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 36
전체 시간: 6,774
