주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 4320t Processor Heat Sink Replacement Guide
필요한 것
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 1개 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 2개
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      댓글 쓰기
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: 2 단계, 이미지 2개 중 1개 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: 2 단계, 이미지 2개 중 2개
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      댓글 쓰기
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: 3 단계, 이미지 1개 중 1개
      • Flip laptop over and open it.
      댓글 쓰기
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: 4 단계, 이미지 1개 중 1개
      • Slightly push up while lifting up on the power button panel to release the panel.
      댓글 쓰기
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: 5 단계, 이미지 1개 중 1개
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      댓글 쓰기
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 1개 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 2개
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      댓글 쓰기
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: 7 단계, 이미지 1개 중 1개
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      댓글 쓰기
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: 8 단계, 이미지 1개 중 1개
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      댓글 쓰기
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: 9 단계, 이미지 1개 중 1개
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      댓글 쓰기
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: 10 단계, 이미지 1개 중 1개
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      댓글 쓰기
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: 11 단계, 이미지 1개 중 1개
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      댓글 쓰기
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: 12 단계, 이미지 1개 중 1개
      • Locate silver holding panel on the left side of the computer.
      댓글 쓰기
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: 13 단계, 이미지 1개 중 1개
      • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
      • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
      댓글 쓰기
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide: 14 단계, 이미지 1개 중 1개
      • Remove holding panel and put aside.
      댓글 쓰기
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide: 15 단계, 이미지 1개 중 1개
      • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
      댓글 쓰기
    5. HP ProBook 4320t Processor Heat Sink Replacement Guide: 16 단계, 이미지 1개 중 1개
      • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
      댓글 쓰기
    6. HP ProBook 4320t Processor Heat Sink Replacement Guide: 17 단계, 이미지 1개 중 1개
      • Lift fan up carefully and replace.
      댓글 쓰기
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: 18 단계, 이미지 1개 중 1개
      • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
      댓글 쓰기
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: 19 단계, 이미지 1개 중 1개
      • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Eric Markham
회원 가입일: 08/29/14
227 평판
안내서 4개를 작성함
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 1,426
