주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 4320t Touchpad Panel Replacement Guide
필요한 것
    1. HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 1개 HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 2개
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      댓글 쓰기
    2. HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: 2 단계, 이미지 2개 중 1개 HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: 2 단계, 이미지 2개 중 2개
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      댓글 쓰기
    3. HP ProBook 4320t Touchpad Panel Replacement Guide, Flip: 3 단계, 이미지 1개 중 1개
      • Flip laptop over and open it.
      댓글 쓰기
    4. HP ProBook 4320t Touchpad Panel Replacement Guide, Push N Lift: 4 단계, 이미지 1개 중 1개
      • Slightly push up while lifting up on the power button panel to release the panel.
      댓글 쓰기
    1. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrewing: 5 단계, 이미지 1개 중 1개
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      댓글 쓰기
    2. HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 1개 HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 2개
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      댓글 쓰기
    3. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: 7 단계, 이미지 1개 중 1개
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      댓글 쓰기
    1. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrew: 8 단계, 이미지 1개 중 1개
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      댓글 쓰기
    2. HP ProBook 4320t Touchpad Panel Replacement Guide, Slide the Panel Off: 9 단계, 이미지 1개 중 1개
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      댓글 쓰기
    3. HP ProBook 4320t Touchpad Panel Replacement Guide, Lift up Carefully: 10 단계, 이미지 1개 중 1개
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      댓글 쓰기
    4. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: 11 단계, 이미지 1개 중 1개
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Joshua
회원 가입일: 09/23/14
134 평판
안내서 6개를 작성함
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 636
