주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 450 G2
필요한 것
    1. HP ProBook 450 G2, Detaching the Bottom Cover and Battery: 1 단계, 이미지 2개 중 1개 HP ProBook 450 G2, Detaching the Bottom Cover and Battery: 1 단계, 이미지 2개 중 2개
      • Carefully remove the main battery.
      • Locate the screw on the bottom side.
      • Unscrew and remove it.
      • Carefully take off the two plastic covers.
      댓글 쓰기
    2. HP ProBook 450 G2, Disassembling the Keyboard: 2 단계, 이미지 3개 중 1개 HP ProBook 450 G2, Disassembling the Keyboard: 2 단계, 이미지 3개 중 2개 HP ProBook 450 G2, Disassembling the Keyboard: 2 단계, 이미지 3개 중 3개
      • Locate the three screws marked with a keyboard icon next to them.
      • Carefully unscrew and remove each of them.
      • Take a thin, flat tool, such as a guitar pick.
      • Gently insert it at the top edge of the keyboard.
      • Carefully slide it along the edge until the keyboard starts to lift or "pop" out.
      • Do not immediately pull out the keyboard.
      • Carefully locate and detach the keyboard cable connecting it to the motherboard.
      댓글 쓰기
    3. HP ProBook 450 G2, Detaching the CD/DVD Drive Unit: 3 단계, 이미지 2개 중 1개 HP ProBook 450 G2, Detaching the CD/DVD Drive Unit: 3 단계, 이미지 2개 중 2개
      • Locate the screw marked with a CD icon next to it.
      • Carefully unscrew and remove it.
      • Carefully pull out the CD-DVD unit.
      댓글 쓰기
    4. HP ProBook 450 G2, Extracting the Hard Drive: 4 단계, 이미지 2개 중 1개 HP ProBook 450 G2, Extracting the Hard Drive: 4 단계, 이미지 2개 중 2개
      • Locate the four screws marked.
      • Slide the disk to the right and then carefully pull it out.
      댓글 쓰기
    5. HP ProBook 450 G2, Disassembling the Casing (1/2): 5 단계, 이미지 3개 중 1개 HP ProBook 450 G2, Disassembling the Casing (1/2): 5 단계, 이미지 3개 중 2개 HP ProBook 450 G2, Disassembling the Casing (1/2): 5 단계, 이미지 3개 중 3개
      • On the bottom locate the 11 (M2.5x3) screws marked and 2 (M2.5x6) - picture 1.
      • On the bottom locate the 6 (M2.5x6) screws hidden under the rubbers - picture 2.
      • Under the keyboard locate the 3 (M2.5x6) screws.
      • Detach all cables connected to the motherboard.
      댓글 쓰기
    6. HP ProBook 450 G2, Disassembling the Casing (2/2): 6 단계, 이미지 2개 중 1개 HP ProBook 450 G2, Disassembling the Casing (2/2): 6 단계, 이미지 2개 중 2개
      • Carefully separate the covers.
      • Be aware that there is an additional cable underneath. Detach this cable with caution.
      댓글 쓰기
    7. HP ProBook 450 G2, Extracting the Motherboard: 7 단계, 이미지 1개 중 1개
      • Locate the five screws marked.
      • To more easily access and detach the cables, gently pull out the motherboard a bit.
      댓글 쓰기
    8. HP ProBook 450 G2, Dismantle cpu cooling pipe: 8 단계, 이미지 2개 중 1개 HP ProBook 450 G2, Dismantle cpu cooling pipe: 8 단계, 이미지 2개 중 2개
      • Locate the six screws marked.
      • Now you can take off cooling pipe and clean it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Klemen Hodžić
회원 가입일: 11/01/20
734 평판
안내서 4개를 작성함
2가이드 댓글
thanks for computer education
kagizo - 답글 공유
شكرا ليكم على الشرح
Abdo elmasry - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 48
지난 30일: 167
전체 시간: 4,582
