주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 450 G4 Fan Replacement
필요한 것
    1. HP ProBook 450 G4 Fan Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
      • Power your laptop off.
      • Flip the laptop over.
      • Orient the laptop so the two vents on the bottom face upward and are further away from you.
      댓글 쓰기
    2. HP ProBook 450 G4 Fan Replacement: 2 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement: 2 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement: 2 단계, 이미지 3개 중 3개
      • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
      • Use the spudger to separate the vent panel from the laptop.
      • Slide the vent panel off the backside of the laptop.
      댓글 쓰기
    3. HP ProBook 450 G4 Fan Replacement: 3 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 3 단계, 이미지 2개 중 2개
      • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
      댓글 쓰기
    4. HP ProBook 450 G4 Fan Replacement: 4 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 4 단계, 이미지 2개 중 2개
      • Use the spudger to lift the left side of the hard drive up.
      • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
      댓글 쓰기
    1. HP ProBook 450 G4 Fan Replacement, Keyboard: 5 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement, Keyboard: 5 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement, Keyboard: 5 단계, 이미지 3개 중 3개
      • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
      • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
      댓글 쓰기
    2. HP ProBook 450 G4 Fan Replacement: 6 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement: 6 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement: 6 단계, 이미지 3개 중 3개
      • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
      • Apply pressure to the black tabs until they release and pop out.
      댓글 쓰기
    3. HP ProBook 450 G4 Fan Replacement: 7 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement: 7 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement: 7 단계, 이미지 3개 중 3개
      • Orient the laptop so the keyboard is facing upwards and towards you.
      • Insert the spudger in between the edge of the keyboard and the computer frame.
      • Slide the spudger around the edge of the keyboard until the keyboard is loose.
      • Gently pull the keyboard away from the body of the laptop.
      • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
      댓글 쓰기
    4. HP ProBook 450 G4 Fan Replacement: 8 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 8 단계, 이미지 2개 중 2개
      • Use a spudger to gently lift up the black locking bar on the keyboard connector.
      • Slide the keyboard ribbon out of the connector.
      • Remove the keyboard.
      • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
      댓글 쓰기
    1. HP ProBook 450 G4 Fan Replacement, Battery: 9 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement, Battery: 9 단계, 이미지 2개 중 2개
      • Flip the laptop back over.
      • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
      댓글 쓰기
    2. HP ProBook 450 G4 Fan Replacement: 10 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 10 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
      댓글 쓰기
    3. HP ProBook 450 G4 Fan Replacement: 11 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 11 단계, 이미지 2개 중 2개
      • Use the spudger to slide the disk drive out of the laptop.
      • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
      댓글 쓰기
    4. HP ProBook 450 G4 Fan Replacement: 12 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement: 12 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement: 12 단계, 이미지 3개 중 3개
      • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
      댓글 쓰기
    5. HP ProBook 450 G4 Fan Replacement: 13 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 13 단계, 이미지 2개 중 2개
      • Flip the laptop back over so it is facing upwards.
      • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
      댓글 쓰기
    6. HP ProBook 450 G4 Fan Replacement: 14 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement: 14 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement: 14 단계, 이미지 3개 중 3개
      • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
      • Be extra careful while disconnecting the cable connectors because they can tear easily.
      댓글 쓰기
    7. HP ProBook 450 G4 Fan Replacement: 15 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 15 단계, 이미지 2개 중 2개
      • Insert the spudger in between the top case of the laptop and its outer frame.
      • Slide the spudger around the edge of the laptop until the top case comes off.
      • Remove the top case.
      댓글 쓰기
    8. HP ProBook 450 G4 Fan Replacement: 16 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 16 단계, 이미지 2개 중 2개
      • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
      댓글 쓰기
    1. HP ProBook 450 G4 Fan Replacement, Fan: 17 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Fan Replacement, Fan: 17 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Fan Replacement, Fan: 17 단계, 이미지 3개 중 3개
      • Use the spudger to disconnect the two cable connectors that secure the fan to the laptop.
      댓글 쓰기
    2. HP ProBook 450 G4 Fan Replacement: 18 단계, 이미지 1개 중 1개
      • Insert the spudger underneath the black wire that wraps over the top of the fan.
      • Use the spudger to pull the black wire away from the top of the fan.
      댓글 쓰기
    3. HP ProBook 450 G4 Fan Replacement: 19 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Fan Replacement: 19 단계, 이미지 2개 중 2개
      • Use a TR9 Torx screwdriver to remove the 6.6mm black screw directly above the fan.
      댓글 쓰기
    4. HP ProBook 450 G4 Fan Replacement: 20 단계, 이미지 1개 중 1개
      • Insert the spudger under the right side of the fan.
      • Use the spudger to gently lift the fan from the laptop.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sebastian Dow
회원 가입일: 01/23/20
1,127 평판
안내서 6개를 작성함
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020 회원
CPSU-WHITE-W20S1G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 33
전체 시간: 3,660
