주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 450 G4 Keyboard Replacement
필요한 것
    1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Keyboard Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
      • Power your laptop off.
      • Flip the laptop over.
      • Orient the laptop so the two vents on the bottom face upward and are further away from you.
      댓글 쓰기
    2. HP ProBook 450 G4 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
      • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
      • Use the spudger to separate the vent panel from the laptop.
      • Slide the vent panel off the backside of the laptop.
      댓글 쓰기
    3. HP ProBook 450 G4 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
      • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
      댓글 쓰기
    4. HP ProBook 450 G4 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
      • Use the spudger to lift the left side of the hard drive up.
      • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
      댓글 쓰기
    1. HP ProBook 450 G4 Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 3개
      • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
      • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
      댓글 쓰기
    2. HP ProBook 450 G4 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
      • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
      • Apply pressure to the black tabs until they release and pop out.
      댓글 쓰기
    3. HP ProBook 450 G4 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
      • Orient the laptop so the keyboard is facing upwards and towards you.
      • Insert the spudger in between the edge of the keyboard and the computer frame.
      • Slide the spudger around the edge of the keyboard until the keyboard is loose.
      • Gently pull the keyboard away from the body of the laptop.
      • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
      댓글 쓰기
    4. HP ProBook 450 G4 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
      • Use a spudger to gently lift up the black locking bar on the keyboard connector.
      • Slide the keyboard ribbon out of the connector.
      • Remove the keyboard.
      • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sebastian Dow
회원 가입일: 01/23/20
1,127 평판
안내서 6개를 작성함
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020 회원
CPSU-WHITE-W20S1G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 91
전체 시간: 9,905
