주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 4520s Optical Drive Replacement
필요한 것
    1. HP ProBook 4520s Optical Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Flip the 4520s upside-down with the front toward you.
      • Push the two latches below the battery inwards at the same time.
      댓글 쓰기
    2. HP ProBook 4520s Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery by holding the latches and sliding the battery away from you.
      댓글 쓰기
    1. HP ProBook 4520s Optical Drive Replacement, Switch Cover: 3 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement, Switch Cover: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
      댓글 쓰기
    2. HP ProBook 4520s Optical Drive Replacement: 4 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement: 4 단계, 이미지 2개 중 2개
      • Flip the 4520s over and rotate it so the back is facing you.
      • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
      댓글 쓰기
    3. HP ProBook 4520s Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
      댓글 쓰기
    4. HP ProBook 4520s Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 HP ProBook 4520s Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 HP ProBook 4520s Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
      • Rotate the 4520s and then open it with the screen facing you.
      • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
      • Lift the switch cover away from the 4520s and set it aside.
      댓글 쓰기
    1. HP ProBook 4520s Optical Drive Replacement, Keyboard: 7 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement, Keyboard: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
      댓글 쓰기
    2. HP ProBook 4520s Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
      • Slide the keyboard panel away from you to free it from the 4520s.
      • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
      댓글 쓰기
    3. HP ProBook 4520s Optical Drive Replacement: 9 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement: 9 단계, 이미지 2개 중 2개
      • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
      • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
      • Remove the cable and lift the keyboard panel up. Set it aside.
      • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
      댓글 쓰기
    1. HP ProBook 4520s Optical Drive Replacement, Optical Drive: 10 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement, Optical Drive: 10 단계, 이미지 2개 중 2개
      • The housing for the optical drive is on the right of the device.
      • Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
      댓글 쓰기
    2. HP ProBook 4520s Optical Drive Replacement: 11 단계, 이미지 1개 중 1개
      • Use a metal spudger to push the optical drive to the right and partially out of the casing.
      댓글 쓰기
    3. HP ProBook 4520s Optical Drive Replacement: 12 단계, 이미지 1개 중 1개
      • Slide the optical drive outward from the 4520s.
      댓글 쓰기
    4. HP ProBook 4520s Optical Drive Replacement: 13 단계, 이미지 2개 중 1개 HP ProBook 4520s Optical Drive Replacement: 13 단계, 이미지 2개 중 2개
      • Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Nicholas Caruso
회원 가입일: 09/21/16
326 평판
안내서 1개를 작성함
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G3
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 35
전체 시간: 2,881
