주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 4520s Screen Replacement
필요한 것
  1. HP ProBook 4520s Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
    댓글 쓰기
  2. HP ProBook 4520s Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by holding the latches and sliding the battery away from you.
    댓글 쓰기
  3. HP ProBook 4520s Screen Replacement, Switch Cover: 3 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement, Switch Cover: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    댓글 쓰기
  4. HP ProBook 4520s Screen Replacement: 4 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    댓글 쓰기
  5. HP ProBook 4520s Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    댓글 쓰기
  6. HP ProBook 4520s Screen Replacement: 6 단계, 이미지 3개 중 1개 HP ProBook 4520s Screen Replacement: 6 단계, 이미지 3개 중 2개 HP ProBook 4520s Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
    댓글 쓰기
  7. HP ProBook 4520s Screen Replacement, Screen: 7 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement, Screen: 7 단계, 이미지 2개 중 2개
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
    댓글 쓰기
  8. HP ProBook 4520s Screen Replacement: 8 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
    댓글 쓰기
  9. HP ProBook 4520s Screen Replacement: 9 단계, 이미지 3개 중 1개 HP ProBook 4520s Screen Replacement: 9 단계, 이미지 3개 중 2개 HP ProBook 4520s Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
    댓글 쓰기
  10. HP ProBook 4520s Screen Replacement: 10 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
    댓글 쓰기
  11. HP ProBook 4520s Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
    댓글 쓰기
  12. HP ProBook 4520s Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Gently push the back cover away.
    댓글 쓰기
  13. HP ProBook 4520s Screen Replacement: 13 단계, 이미지 3개 중 1개 HP ProBook 4520s Screen Replacement: 13 단계, 이미지 3개 중 2개 HP ProBook 4520s Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
    댓글 쓰기
  14. HP ProBook 4520s Screen Replacement: 14 단계, 이미지 3개 중 1개 HP ProBook 4520s Screen Replacement: 14 단계, 이미지 3개 중 2개 HP ProBook 4520s Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Peel the ribbon cable away from the screen.
    댓글 쓰기
  15. HP ProBook 4520s Screen Replacement: 15 단계, 이미지 2개 중 1개 HP ProBook 4520s Screen Replacement: 15 단계, 이미지 2개 중 2개
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Robert Spencer Harrison
회원 가입일: 09/21/16
1,422 평판
안내서 4개를 작성함
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G3
5 회원들
안내서 8개를 작성함
2가이드 댓글
I need back cover hp i5 probook 4520s
amir86216 - 답글 공유
I need speakers hp probook 4520s i5
Osagie Rmd - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 62
전체 시간: 6,985
