주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 455 G7 RAM Replacement
필요한 것
    1. HP ProBook 455 G7 RAM Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      댓글 쓰기
    2. HP ProBook 455 G7 RAM Replacement: 2 단계, 이미지 3개 중 1개 HP ProBook 455 G7 RAM Replacement: 2 단계, 이미지 3개 중 2개 HP ProBook 455 G7 RAM Replacement: 2 단계, 이미지 3개 중 3개
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      댓글 쓰기
    1. HP ProBook 455 G7 RAM Replacement, Battery: 3 단계, 이미지 3개 중 1개 HP ProBook 455 G7 RAM Replacement, Battery: 3 단계, 이미지 3개 중 2개 HP ProBook 455 G7 RAM Replacement, Battery: 3 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      댓글 쓰기
    1. HP ProBook 455 G7 RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      댓글 쓰기
    2. HP ProBook 455 G7 RAM Replacement: 5 단계, 이미지 1개 중 1개
      • The RAM stick should pop up at an angle.
      댓글 쓰기
    3. HP ProBook 455 G7 RAM Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully pull the module directly out of its socket.
      • Align the notch on the new RAM module with the slot in the connector.
      • Slide the module in at an angle, then press down until it clicks into place.
      • The HP ProBook 455 G7 typically supports DDR4 SO-DIMM RAM up to 32 GB (2 × 16 GB). Make sure both sticks are properly seated before reassembling.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andiany Reynoso
회원 가입일: 10/15/25
253 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-6, Botvin Fall 2025 UMass Dartmouth, Team 1-6, Botvin Fall 2025 회원
UMASSD-BOTVIN-F25S1G6
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 26
전체 시간: 161
