주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 640 G1 Midframe Replacement
필요한 것
    1. HP ProBook 640 G1 Midframe Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn the laptop upside down to show the battery lock slider.
      • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
      댓글 쓰기
    2. HP ProBook 640 G1 Midframe Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the battery slider all the way to the left, towards the battery symbol.
      • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
      댓글 쓰기
    3. HP ProBook 640 G1 Midframe Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the battery by sliding it away from the laptop while holding the battery locker.
      • The battery should slide out with ease.
      댓글 쓰기
    1. HP ProBook 640 G1 Midframe Replacement, Back Panel: 4 단계, 이미지 2개 중 1개 HP ProBook 640 G1 Midframe Replacement, Back Panel: 4 단계, 이미지 2개 중 2개
      • Slide down and pull up on the cover to remove it.
      댓글 쓰기
    1. HP ProBook 640 G1 Midframe Replacement, Midframe: 5 단계, 이미지 3개 중 1개 HP ProBook 640 G1 Midframe Replacement, Midframe: 5 단계, 이미지 3개 중 2개 HP ProBook 640 G1 Midframe Replacement, Midframe: 5 단계, 이미지 3개 중 3개
      • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
      • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
      • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
      • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
      댓글 쓰기
    2. HP ProBook 640 G1 Midframe Replacement: 6 단계, 이미지 2개 중 1개 HP ProBook 640 G1 Midframe Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the disk drive by gently pulling it out.
      • Remove the two 3 mm screws using a Phillips #1 screwdriver.
      • Only one screw is visible in the photo the second screw is located directly above it.
      댓글 쓰기
    3. HP ProBook 640 G1 Midframe Replacement: 7 단계, 이미지 2개 중 1개 HP ProBook 640 G1 Midframe Replacement: 7 단계, 이미지 2개 중 2개
      • Gently pull up on the midframe, gripping it from the inside.
      • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Carter Wilcomb
회원 가입일: 11/04/25
199 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 회원
UMASSD-BISWOKARMA-F25S4G2
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 55
전체 시간: 312
