주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 640 G5 Keyboard Replacement
필요한 것
    1. HP ProBook 640 G5 Keyboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
      • Shut down the HP ProBook 640 G5 completely.
      • Disconnect the power adapter and all connected peripherals.
      • Press and hold the power button for 5 seconds to discharge remaining electricity.
      댓글 쓰기
    2. HP ProBook 640 G5 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the laptop over so the bottom is facing up.
      • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
      • These screws are captive, so they will loosen but remain attached to the cover.
      • Remove two black 6mm screws using a TR7 Torx screwdriver.
      • Insert a plastic opening tool into the seam and gently pry around the edges.
      • Lift the bottom cover away from the laptop.
      댓글 쓰기
    1. HP ProBook 640 G5 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 HP ProBook 640 G5 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
      • Loosen the two captive screws using a Phillips #1 screwdriver.
      • Both of these screws have keyboard icons next to them.
      댓글 쓰기
    2. HP ProBook 640 G5 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP ProBook 640 G5 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
      • Turn the laptop on its side and open the display panel so the laptop sits upright.
      • While supporting the keyboard firmly, insert a keyboard release tool into the opening with the keyboard icon.
      • Carefully turn the laptop right side up.
      댓글 쓰기
    3. HP ProBook 640 G5 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 HP ProBook 640 G5 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 HP ProBook 640 G5 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
      • The keyboard is held by three cables; do not try and remove the keyboard until all three cables are detached.
      • Lift the rear edge of the keyboard up gently making sure not to rip or tug on the cable connectors.
      • Disconnect in order as pictured:
      • Disconnect the keyboard backlight ribbon cable from the system board.
      • Disconnect the point stick ribbon cable from the system board.
      • Disconnect the keyboard ribbon cable from the system board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Eric Olivarez
회원 가입일: 02/23/26
449 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 22
전체 시간: 99
