주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 640 G5 WLAN Module Replacement
필요한 것
    1. HP ProBook 640 G5 WLAN Module Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
      • Shut down the HP ProBook 640 G5 completely.
      • Disconnect the power adapter and all connected peripherals.
      • Press and hold the power button for 5 seconds to discharge remaining electricity.
      댓글 쓰기
    2. HP ProBook 640 G5 WLAN Module Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the laptop over so the bottom is facing up.
      • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
      • These screws are captive, so they will loosen but remain attached to the cover.
      • Remove two black 6mm screws using a TR7 Torx screwdriver.
      • Insert a plastic opening tool into the seam and gently pry around the edges.
      • Lift the bottom cover away from the laptop.
      댓글 쓰기
    1. HP ProBook 640 G5 WLAN Module Replacement, WLAN Module: 3 단계, 이미지 2개 중 1개 HP ProBook 640 G5 WLAN Module Replacement, WLAN Module: 3 단계, 이미지 2개 중 2개
      • When replacing the WLAN module, avoid touching the gold contacts and black chips. Handle the stick only by its outer edges or plastic/metal shielding. Touching the chips or gold contacts can introduce static electricity or oil from your fingers, potentially causing damage or poor connectivity.
      • Locate the WLAN module.
      • You can identify it by its small size (usually M.2 2230) or labels such as WLAN, Wi-Fi, or M.2 nearby.
      • Remove the single screw holding the WLAN card down.
      댓글 쓰기
    2. HP ProBook 640 G5 WLAN Module Replacement: 4 단계, 이미지 1개 중 1개
      • The card will pop up at an angle (about 25–30 degrees).
      • Slide it straight out of the socket.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Eric Olivarez
회원 가입일: 02/23/26
449 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 114
