주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP ProBook 650 G4 Keyboard Replacement
필요한 것
    1. HP ProBook 650 G4 Keyboard Replacement, Remove Back Plate: 1 단계, 이미지 1개 중 1개
      • Loosen the 8 Philips screws circled in red in the photo. These screws are captive and should not come out fully.
      • Use pry tool starting at one of the hinges to release the clips all around the back plate
      • Remove plate and set aside.
      댓글 쓰기
    2. HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: 2 단계, 이미지 3개 중 1개 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: 2 단계, 이미지 3개 중 2개 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: 2 단계, 이미지 3개 중 3개
      • Unscrew the 3 Philips screws by the keyboard icons. (Circled in red)
      • The screws are captive and should not be removed fully.
      • Open the laptop screen
      • Use keyboard removal tool to push out the keyboard (circled in green)
      • anything that fits in the hole could be used if tool not available.
      댓글 쓰기
    3. HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: 3 단계, 이미지 2개 중 1개 HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: 3 단계, 이미지 2개 중 2개
      • Work around the keyboard releasing the clips.
      • Clips are only located on the top, left, and right of the keyboard.
      • flip the keyboard towards the mouse pad taking care not to damage the ribbon cables.
      댓글 쓰기
    4. HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: 4 단계, 이미지 3개 중 1개 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: 4 단계, 이미지 3개 중 2개 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: 4 단계, 이미지 3개 중 3개
      • with a plastic spudger tool flip up the black clips to release the ribbon cables
      • Gently pull out the cables, there should be no resistance if the clips were opened properly.
      • There may be some adhesive connecting the cable to the keyboard (green arrow).
      댓글 쓰기
    5. HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: 5 단계, 이미지 2개 중 1개 HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: 5 단계, 이미지 2개 중 2개
      • Gently fold the new ribbon cables at the 15B line
      • Gently push in the ribbon cables and press down the black clips.
      • Make sure that the cables are pushed in far enough. They have a line marking how far they should be inserted.
      • Slide in the bottom clips of the keyboard and flip towards the screen
      • Push the keyboard all around until all of the clips click into place.
      댓글 쓰기
    6. HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: 6 단계, 이미지 2개 중 1개 HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: 6 단계, 이미지 2개 중 2개
      • Screw in the 3 keyboard screws
      • Push the back plate on and screw in the 8 screws
      • Go around the back plate making sure that it is clipped in all around.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
David Salerno
회원 가입일: 09/14/11
823 평판
안내서 4개를 작성함
1가이드 댓글
Datasheet motherboard
No power in d
evice
Mahmoud Ahmed - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 73
전체 시간: 4,533
