주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Slate 7 Plus 4200US Battery Replacement
필요한 것
    1. HP Slate 7 Plus 4200US Battery Replacement, Tablet Cover: 1 단계, 이미지 1개 중 1개
      • Turn off the tablet and disconnect the power and all external devices from the tablet.
      • Position the tablet with the display panel down and the right side toward you.
      • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
      댓글 쓰기
    2. HP Slate 7 Plus 4200US Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Slate 7 Plus 4200US Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
      댓글 쓰기
    3. HP Slate 7 Plus 4200US Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Slate 7 Plus 4200US Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Slate 7 Plus 4200US Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Pry open the back cover to take it off.
      댓글 쓰기
    1. HP Slate 7 Plus 4200US Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 HP Slate 7 Plus 4200US Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 HP Slate 7 Plus 4200US Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
      • Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
      • The battery cables are soldered to the system in the following sequence, top to bottom: red, blue, green, yellow, black.
      댓글 쓰기
    2. HP Slate 7 Plus 4200US Battery Replacement: 5 단계, 이미지 3개 중 1개 HP Slate 7 Plus 4200US Battery Replacement: 5 단계, 이미지 3개 중 2개 HP Slate 7 Plus 4200US Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
      • The battery is attached to the display panel assembly with double-sided adhesive. Make sure to firmly pull the battery.
      • The regular black nylon spudger should be used whenever possible, especially around batteries.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jessica Andrade
회원 가입일: 10/04/16
884 평판
안내서 7개를 작성함
USF Tampa, Team 3-1, Sullivan Fall 2016 USF Tampa, Team 3-1, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G1
3 회원들
안내서 14개를 작성함
1가이드 댓글
Bonjour, où peut on trouver une batterie svp ?
C'est pour une tablette HP Slate7 Plus.
Merci pour votre aide.
Cordialement. Stéphane
dingo346 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 27
전체 시간: 2,476
