주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 11-d010nr Battery Replacement
필요한 것
  1. HP Stream 11-d010nr Battery Replacement, Pry out the inserts: 1 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Battery Replacement, Pry out the inserts: 1 단계, 이미지 2개 중 2개
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    댓글 쓰기
  2. HP Stream 11-d010nr Battery Replacement, Unscrew the back cover: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    댓글 쓰기
  3. HP Stream 11-d010nr Battery Replacement, Pry the keyboard casing up: 3 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Battery Replacement, Pry the keyboard casing up: 3 단계, 이미지 2개 중 2개
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    댓글 쓰기
  4. HP Stream 11-d010nr Battery Replacement, Identify the connectors: 4 단계, 이미지 1개 중 1개
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    댓글 쓰기
  5. HP Stream 11-d010nr Battery Replacement, Disconnect the cables: 5 단계, 이미지 3개 중 1개 HP Stream 11-d010nr Battery Replacement, Disconnect the cables: 5 단계, 이미지 3개 중 2개 HP Stream 11-d010nr Battery Replacement, Disconnect the cables: 5 단계, 이미지 3개 중 3개
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    댓글 쓰기
  6. HP Stream 11-d010nr Battery Replacement, Lift the keyboard out: 6 단계, 이미지 1개 중 1개
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    댓글 쓰기
  7. HP Stream 11-d010nr Battery Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    댓글 쓰기
  8. HP Stream 11-d010nr Battery Replacement: 8 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Zachary Heisler
회원 가입일: 01/24/19
382 평판
안내서 3개를 작성함
Cal Poly, Team S1-G3, White Winter 2019 Cal Poly, Team S1-G3, White Winter 2019 회원
CPSU-WHITE-W19S1G3
4 회원들
안내서 11개를 작성함
3가이드 댓글
HP lists the screws on the back cover as size pm1.9x5.6. What is wrong with HP that they would use such an odd size? I tried 2x6mm and they seem to work fine.
Greg Worrel - 답글 공유
Me podrias ayudar con el numero de serie del boton de encendido
sam Carrizales - 답글 공유
O donde lo puedo conseguir
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 60
전체 시간: 3,565
