주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 11-d010nr Webcam Replacement
필요한 것
  1. HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: 1 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: 1 단계, 이미지 2개 중 2개
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    댓글 쓰기
  2. HP Stream 11-d010nr Webcam Replacement, Unscrew the back cover: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    댓글 쓰기
  3. HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: 3 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: 3 단계, 이미지 2개 중 2개
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    댓글 쓰기
  4. HP Stream 11-d010nr Webcam Replacement, Identify the connectors: 4 단계, 이미지 1개 중 1개
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    댓글 쓰기
  5. HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 5 단계, 이미지 3개 중 1개 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 5 단계, 이미지 3개 중 2개 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 5 단계, 이미지 3개 중 3개
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    댓글 쓰기
  6. HP Stream 11-d010nr Webcam Replacement, Lift the keyboard out: 6 단계, 이미지 1개 중 1개
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    댓글 쓰기
  7. HP Stream 11-d010nr Webcam Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    댓글 쓰기
  8. HP Stream 11-d010nr Webcam Replacement: 8 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    댓글 쓰기
  9. HP Stream 11-d010nr Webcam Replacement, Wifi Chip: 9 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement, Wifi Chip: 9 단계, 이미지 2개 중 2개
    • Unplug the black wire attached to the wireless chip.
    댓글 쓰기
  10. HP Stream 11-d010nr Webcam Replacement: 10 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
    • Lift the wireless chip up and out.
    댓글 쓰기
  11. HP Stream 11-d010nr Webcam Replacement, Webcam: 11 단계, 이미지 3개 중 1개 HP Stream 11-d010nr Webcam Replacement, Webcam: 11 단계, 이미지 3개 중 2개 HP Stream 11-d010nr Webcam Replacement, Webcam: 11 단계, 이미지 3개 중 3개
    • Flip up the flap and unplug the display cord from the motherboard.
    댓글 쓰기
  12. HP Stream 11-d010nr Webcam Replacement: 12 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement: 12 단계, 이미지 2개 중 2개
    • Using a JIS #1 screwdriver, remove the four 2.2 mm screws holding monitor to body.
    댓글 쓰기
  13. HP Stream 11-d010nr Webcam Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the screw covers from the lid.
    • Unscrew the two 2.2 mm #000 Phillips screws.
    댓글 쓰기
  14. HP Stream 11-d010nr Webcam Replacement: 14 단계, 이미지 1개 중 1개
    • Open the upper lid with the iFixit opening tool.
    댓글 쓰기
  15. HP Stream 11-d010nr Webcam Replacement: 15 단계, 이미지 2개 중 1개 HP Stream 11-d010nr Webcam Replacement: 15 단계, 이미지 2개 중 2개
    • Disconnect the webcam cord using tweezers.
    • Remove the webcam using tweezers.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Zachary Heisler
회원 가입일: 01/24/19
382 평판
안내서 3개를 작성함
Cal Poly, Team S1-G3, White Winter 2019 Cal Poly, Team S1-G3, White Winter 2019 회원
CPSU-WHITE-W19S1G3
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 35
전체 시간: 704
