주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 11-d020nr Screen Replacement
필요한 것
    1. HP Stream 11-d020nr Screen Replacement, Lower Case: 1 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Screen Replacement, Lower Case: 1 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Screen Replacement, Lower Case: 1 단계, 이미지 3개 중 3개
      • Before disassembly, unplug and power off the Stream 11.
      • Pry off the two elliptical rubber inserts (one in each corner).
      • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
      댓글 쓰기
    2. HP Stream 11-d020nr Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Stream 11-d020nr Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the eleven 5.6 mm Phillips #00 screws.
      댓글 쓰기
    3. HP Stream 11-d020nr Screen Replacement: 3 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Screen Replacement: 3 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Turn the computer upright and lift the screen.
      • Carefully use a spudger to pry the plastic keyboard cover from the base.
      • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
      • Work the spudger around the cover to release the clips attaching the cover to the base.
      • Be patient when removing the cover, as there are many clips and it may take some time.
      댓글 쓰기
    4. HP Stream 11-d020nr Screen Replacement: 4 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Screen Replacement: 4 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Screen Replacement: 4 단계, 이미지 3개 중 3개
      • Disconnect the cable connecting the ClickPad to the base.
      • Remove the plastic keyboard cover.
      • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
      댓글 쓰기
    1. HP Stream 11-d020nr Screen Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 HP Stream 11-d020nr Screen Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
      • Tilt the top of the keyboard plate up until you separate it from the base.
      • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
      댓글 쓰기
    2. HP Stream 11-d020nr Screen Replacement: 6 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Screen Replacement: 6 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Screen Replacement: 6 단계, 이미지 3개 중 3개
      • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
      • After disengaging the connectors, gently unplug both ribbon cables.
      댓글 쓰기
    1. HP Stream 11-d020nr Screen Replacement, Lid: 7 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Screen Replacement, Lid: 7 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Screen Replacement, Lid: 7 단계, 이미지 3개 중 3개
      • Lift the black flap on the display cable ZIF connector.
      • After lifting the flap, gently pull the display cable from its socket.
      • Disconnect the wireless antenna from the wireless card.
      • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
      댓글 쓰기
    2. HP Stream 11-d020nr Screen Replacement: 8 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Screen Replacement: 8 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Screen Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use tweezers to remove the screw covers from the lid.
      • Remove the two 2.2 mm Phillips #000 screws.
      • Use a plastic opening tool to disengage the front part of the lid.
      댓글 쓰기
    1. HP Stream 11-d020nr Screen Replacement, Screen: 9 단계, 이미지 2개 중 1개 HP Stream 11-d020nr Screen Replacement, Screen: 9 단계, 이미지 2개 중 2개
      • Unscrew the four 3.3mm Phillips #000 screws as indicated.
      • Lift the screen from the lid carefully.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spenser Mason
회원 가입일: 02/04/16
1,781 평판
안내서 6개를 작성함
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G5
5 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 6,432
