주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 11-d020nr Webcam Replacement
필요한 것
  1. HP Stream 11-d020nr Webcam Replacement, Lower Case: 1 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Webcam Replacement, Lower Case: 1 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Webcam Replacement, Lower Case: 1 단계, 이미지 3개 중 3개
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
    댓글 쓰기
  2. HP Stream 11-d020nr Webcam Replacement: 2 단계, 이미지 2개 중 1개 HP Stream 11-d020nr Webcam Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eleven 5.6 mm Phillips #00 screws.
    댓글 쓰기
  3. HP Stream 11-d020nr Webcam Replacement: 3 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Webcam Replacement: 3 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Webcam Replacement: 3 단계, 이미지 3개 중 3개
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
    댓글 쓰기
  4. HP Stream 11-d020nr Webcam Replacement: 4 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Webcam Replacement: 4 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Webcam Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
    댓글 쓰기
  5. HP Stream 11-d020nr Webcam Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 HP Stream 11-d020nr Webcam Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
    댓글 쓰기
  6. HP Stream 11-d020nr Webcam Replacement: 6 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Webcam Replacement: 6 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Webcam Replacement: 6 단계, 이미지 3개 중 3개
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
    댓글 쓰기
  7. HP Stream 11-d020nr Webcam Replacement, Lid: 7 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Webcam Replacement, Lid: 7 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Webcam Replacement, Lid: 7 단계, 이미지 3개 중 3개
    • Lift the black flap on the display cable ZIF connector.
    • After lifting the flap, gently pull the display cable from its socket.
    • Disconnect the wireless antenna from the wireless card.
    • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
    댓글 쓰기
  8. HP Stream 11-d020nr Webcam Replacement: 8 단계, 이미지 3개 중 1개 HP Stream 11-d020nr Webcam Replacement: 8 단계, 이미지 3개 중 2개 HP Stream 11-d020nr Webcam Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the screw covers from the lid.
    • Remove the two 2.2 mm Phillips #000 screws.
    • Use a plastic opening tool to disengage the front part of the lid.
    댓글 쓰기
  9. HP Stream 11-d020nr Webcam Replacement, Webcam: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to remove the wire connected to the webcam.
    댓글 쓰기
  10. HP Stream 11-d020nr Webcam Replacement: 10 단계, 이미지 1개 중 1개
    • Use the tweezers to pull the webcam off of the frame.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Spenser Mason
회원 가입일: 02/04/16
1,781 평판
안내서 6개를 작성함
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G5
5 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 708
