주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 13-c002dx Wireless Card Replacement
필요한 것
  1. HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
    댓글 쓰기
  2. HP Stream 13-c002dx Wireless Card  Replacement: 2 단계, 이미지 3개 중 1개 HP Stream 13-c002dx Wireless Card  Replacement: 2 단계, 이미지 3개 중 2개 HP Stream 13-c002dx Wireless Card  Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
    댓글 쓰기
  3. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 3 단계, 이미지 3개 중 1개 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 3 단계, 이미지 3개 중 2개 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 3 단계, 이미지 3개 중 3개
    • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
    • Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
    • Once the wire is removed, set it aside so it does not get damaged.
    댓글 쓰기
  4. HP Stream 13-c002dx Wireless Card  Replacement: 4 단계, 이미지 3개 중 1개 HP Stream 13-c002dx Wireless Card  Replacement: 4 단계, 이미지 3개 중 2개 HP Stream 13-c002dx Wireless Card  Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the screw holding the wireless card in place.
    • With the screw removed, gently pull back the Wi-Fi card and then lift it out of the laptop. You are now ready to insert the new wireless card.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Hailee McCraw
회원 가입일: 01/23/18
221 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 36
전체 시간: 1,776
