주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 13-c010nr Display Replacement
필요한 것
    1. HP Stream 13-c010nr Display Replacement, laptop: 1 단계, 이미지 1개 중 1개
      • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
      댓글 쓰기
    2. HP Stream 13-c010nr Display Replacement: 2 단계, 이미지 2개 중 1개 HP Stream 13-c010nr Display Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
      댓글 쓰기
    3. HP Stream 13-c010nr Display Replacement: 3 단계, 이미지 2개 중 1개 HP Stream 13-c010nr Display Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the laptop over and open it up.
      • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
      • Lift up the keyboard.
      • Ribbon cables still connect the two pieces.
      댓글 쓰기
    4. HP Stream 13-c010nr Display Replacement: 4 단계, 이미지 1개 중 1개
      • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
      • Pull up the ribbon cables from their sockets.
      댓글 쓰기
    1. HP Stream 13-c010nr Display Replacement, Display: 5 단계, 이미지 1개 중 1개
      • Remove the screw covers from the bottom corner edges of the screen.
      댓글 쓰기
    2. HP Stream 13-c010nr Display Replacement: 6 단계, 이미지 2개 중 1개 HP Stream 13-c010nr Display Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the two 5mm Phillips #0 screws from the screen bezel.
      댓글 쓰기
    3. HP Stream 13-c010nr Display Replacement: 7 단계, 이미지 2개 중 1개 HP Stream 13-c010nr Display Replacement: 7 단계, 이미지 2개 중 2개
      • Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
      • Pry upwards on the plastic opening tool to separate the bezel from the display.
      댓글 쓰기
    4. HP Stream 13-c010nr Display Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the four 3mm Phillips #0 screws from the screen.
      댓글 쓰기
    5. HP Stream 13-c010nr Display Replacement: 9 단계, 이미지 1개 중 1개
      • Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
      • Pull the ribbon cable out of the ZIF socket.
      • Remove the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Keegan Lapham
회원 가입일: 02/22/18
759 평판
안내서 6개를 작성함
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G3
4 회원들
안내서 38개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 24
전체 시간: 1,062
