주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 7 Motherboard Replacement
필요한 것
    1. HP Stream 7  Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Stream 7  Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      댓글 쓰기
    2. HP Stream 7  Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP Stream 7  Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      댓글 쓰기
    3. HP Stream 7  Motherboard Replacement: 3 단계, 이미지 2개 중 1개 HP Stream 7  Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      댓글 쓰기
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      댓글 쓰기
    2. HP Stream 7  Motherboard Replacement: 5 단계, 이미지 2개 중 1개 HP Stream 7  Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      댓글 쓰기
    3. HP Stream 7  Motherboard Replacement: 6 단계, 이미지 2개 중 1개 HP Stream 7  Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Justin Schnorf
회원 가입일: 10/03/16
252 평판
안내서 2개를 작성함
Cal Poly, Team 18-5, Forte Fall 2016 Cal Poly, Team 18-5, Forte Fall 2016 회원
CPSU-FORTE-F16S18G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 43
전체 시간: 2,108
