주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
필요한 것
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: 1 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: 1 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: 1 단계, 이미지 3개 중 3개
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    댓글 쓰기
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: 2 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: 2 단계, 이미지 2개 중 2개
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    댓글 쓰기
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 3 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 3 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 3 단계, 이미지 3개 중 3개
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    댓글 쓰기
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 4 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    댓글 쓰기
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: 5 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: 5 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: 5 단계, 이미지 3개 중 3개
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clement Cheung
회원 가입일: 01/24/19
643 평판
안내서 5개를 작성함
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 회원
CPSU-WHITE-W19S18G5
2 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 1,966
