주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP pavilion 15-cs3073cl Disassembly
필요한 것
    1. HP pavilion 15-cs3073cl Disassembly, Remove front screws: 1 단계, 이미지 1개 중 1개
      • Begin by removing the 3 screws on the bottom front of the laptop. A Phillips #00 works well here.
      댓글 쓰기
    2. HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: 2 단계, 이미지 2개 중 1개 HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: 2 단계, 이미지 2개 중 2개
      • There are 3 screws hidden under the rubber pads. Using a pry tool or something thin like a credit card to remove the glued on rubber pads you will find one screw on the left back and 2 under the right pad. Phillips #0 works well to remove these larger screws.
      댓글 쓰기
    3. HP pavilion 15-cs3073cl Disassembly, Pry the upper and lower body: 3 단계, 이미지 1개 중 1개
      • With a thin pry bar or credit card push in between the upper and lower parts of the body and you'll hear a clicking sound as the tabs release the 2 pieces. Go all around the laptop until the bottom cover is completely off.
      댓글 쓰기
    4. HP pavilion 15-cs3073cl Disassembly, HDD removal: 4 단계, 이미지 1개 중 1개
      • If you're upgrading the HDD remove the 2 screws on the exposed side and lift from that side. The other side is being held by 2 rubber nipples on a thin rubber strip that will bend as you pull the drive.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Josue Nolasco
회원 가입일: 01/13/17
298 평판
안내서 1개를 작성함
Green Shield Technology Green Shield Technology 회원
Business
2 회원들
안내서 5개를 작성함
3가이드 댓글
Good day,
Can we have the part number?
Cate Ledezma - 답글 공유
Hello, I’m not sure what part number you’re looking for. These instructions are for the disassembly of the laptop as stated in the title. Once disassembled, you can replace any parts you need.
Josue Nolasco - 답글 공유
This disassembly guide seems to only have the removal of the bottom cover and HDD, did I miss steps somewhere? Thanks!
John Doe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 122
전체 시간: 10,022
