주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Desire 700 Dual Sim Front Facing Camera Replacement
필요한 것
    1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Use the spudger to pry the back cover off.
      댓글 쓰기
    2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Battery: 2 단계, 이미지 1개 중 1개
      • Use spudger tool to pry under the battery to lift it up and out.
      댓글 쓰기
    1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Remove 8 Torx Screws: 3 단계, 이미지 1개 중 1개
      • Remove eight 8.3mm T4 screws with the Torx screwdriver.
      댓글 쓰기
    2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Prying Off Rear Panel: 4 단계, 이미지 1개 중 1개
      • Pry the back panel of the screen using the plastic opener.
      • Work your way gently around the device, using picks as necessary to keep the back panel separated.
      • Use caution not to damage the device, as it takes force to remove the rear panel.
      댓글 쓰기
    1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
      댓글 쓰기
    2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Disconnect Vibrator Wire: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
      댓글 쓰기
    3. HTC Desire 700 Dual Sim Front Facing Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Remove volume control button ribbon with tweezers.
      댓글 쓰기
    4. HTC Desire 700 Dual Sim Front Facing Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Carefully remove the ribbon attached to the top of the motherboard.
      댓글 쓰기
    5. HTC Desire 700 Dual Sim Front Facing Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
      댓글 쓰기
    1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Camera: 10 단계, 이미지 1개 중 1개
      • Remove the camera using the plastic opening tool as shown.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Steven Pate
회원 가입일: 09/23/14
196 평판
안내서 7개를 작성함
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G3
4 회원들
안내서 49개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 36
전체 시간: 1,124
