주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Droid Eris Battery Replacement
필요한 것
    1. HTC Droid Eris Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HTC Droid Eris Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Place the device on a flat surface with the headphone outlet/jack facing away from you.
      • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
      • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
      댓글 쓰기
    2. HTC Droid Eris Battery Replacement: 2 단계, 이미지 2개 중 1개 HTC Droid Eris Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
      • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
      • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
12다른 기여자 명과 함께
Elizabeth Ofori
회원 가입일: 04/15/13
648 평판
안내서 6개를 작성함
SUNY Cortland, Team 1-2, Getto Spring 2013 SUNY Cortland, Team 1-2, Getto Spring 2013 회원
SUNYCORT-GETTO-S13S1G2
5 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 34
전체 시간: 1,126
