주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Flyer Battery Replacement
필요한 것
  1. HTC Flyer Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 HTC Flyer Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 HTC Flyer Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
    댓글 쓰기
  2. HTC Flyer Battery Replacement: 2 단계, 이미지 3개 중 1개 HTC Flyer Battery Replacement: 2 단계, 이미지 3개 중 2개 HTC Flyer Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
    댓글 쓰기
  3. HTC Flyer Battery Replacement: 3 단계, 이미지 3개 중 1개 HTC Flyer Battery Replacement: 3 단계, 이미지 3개 중 2개 HTC Flyer Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
    댓글 쓰기
  4. HTC Flyer Battery Replacement: 4 단계, 이미지 2개 중 1개 HTC Flyer Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
    댓글 쓰기
  5. HTC Flyer Battery Replacement, Battery: 5 단계, 이미지 2개 중 1개 HTC Flyer Battery Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
    댓글 쓰기
  6. HTC Flyer Battery Replacement: 6 단계, 이미지 3개 중 1개 HTC Flyer Battery Replacement: 6 단계, 이미지 3개 중 2개 HTC Flyer Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
    댓글 쓰기
  7. HTC Flyer Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
    댓글 쓰기
  8. HTC Flyer Battery Replacement: 8 단계, 이미지 3개 중 1개 HTC Flyer Battery Replacement: 8 단계, 이미지 3개 중 2개 HTC Flyer Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ana
회원 가입일: 10/07/14
489 평판
안내서 2개를 작성함
USF Tampa, Team 8-5, Leahy Fall 2014 USF Tampa, Team 8-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G5
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 39
전체 시간: 2,421
