주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Fortress Back Panel Replacement
필요한 것
    1. HTC Fortress Back Panel Replacement, Battery: 1 단계, 이미지 2개 중 1개 HTC Fortress Back Panel Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Remove the back cover of the device by sliding it upward.
      • You may need to remove the phone stylus first.
      댓글 쓰기
    2. HTC Fortress Back Panel Replacement: 2 단계, 이미지 2개 중 1개 HTC Fortress Back Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the battery by pulling it away from the back of the phone.
      댓글 쓰기
    1. HTC Fortress Back Panel Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 HTC Fortress Back Panel Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 HTC Fortress Back Panel Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
      • Insert the stylus into the small slot.
      • Use the stylus as a lever to push the sim card out of its fitting.
      • Use your finger to slide the card out the rest of the way.
      댓글 쓰기
    1. HTC Fortress Back Panel Replacement, Back Panel: 4 단계, 이미지 2개 중 1개 HTC Fortress Back Panel Replacement, Back Panel: 4 단계, 이미지 2개 중 2개
      • Remove the two 4mm-long screws using the T4 Torx Screwdriver.
      • Remove the two 3.5mm-long screws using the T4 Torx Screwdriver.
      • Keep the 4mm-long upper screws separate from the 3.5mm-long bottom screws. They are different!
      댓글 쓰기
    2. HTC Fortress Back Panel Replacement: 5 단계, 이미지 3개 중 1개 HTC Fortress Back Panel Replacement: 5 단계, 이미지 3개 중 2개 HTC Fortress Back Panel Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the camera panel by hand (black cover above the battery slot).
      • Be careful, there is a cable attached underneath the camera panel.
      • Gently pull the camera panel away from the phone to detach the cable.
      • During reassembly, reattach the cable by holding the silver-plated ending slightly above its slot and using the spudger to gently press it into its fitting. Then, insert the camera panel so it is flush with the back panel again.
      댓글 쓰기
    3. HTC Fortress Back Panel Replacement: 6 단계, 이미지 3개 중 1개 HTC Fortress Back Panel Replacement: 6 단계, 이미지 3개 중 2개 HTC Fortress Back Panel Replacement: 6 단계, 이미지 3개 중 3개
      • Notice the 8 small clips around the perimeter of the phone shown here...
      댓글 쓰기
    4. HTC Fortress Back Panel Replacement: 7 단계, 이미지 2개 중 1개 HTC Fortress Back Panel Replacement: 7 단계, 이미지 2개 중 2개
      • ...and the 2 clips shown here.
      • Insert the spudger into the seam along the edge of phone, and gently pry the back panel from the keyboard. Follow the seam along the perimeter of the phone.
      • Only pry right next to the clips shown in the above step, as well as the clips next to the charging port.
      댓글 쓰기
    5. HTC Fortress Back Panel Replacement: 8 단계, 이미지 2개 중 1개 HTC Fortress Back Panel Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the back panel by pulling it away from the phone.
      • Slide the panel downwards as you remove it, making sure to clear the charging port.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Lucas David
회원 가입일: 04/19/13
540 평판
안내서 9개를 작성함
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 회원
CPSU-MANESS-S13S4G13
4 회원들
안내서 108개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 913
